-   -   First engine drop - Mystery transmission (http://forums.pelicanparts.com/porsche-911-technical-forum/784405-first-engine-drop-mystery-transmission.html)
maresdesign 11-29-2013 06:53 AM
Fellow Pelican's I dropped my motor/tranny together yesterday on my 1971 911E. I thought the transmission would be difficult to separate from the motor but after I un-bolted it from the motor it separated very easily.
I thought the 71 tranny's where the "Pull" type? I did find "902/1" stamped on it. I also noticed the Oil tank had the two "nipples" on it consistent with the "Sportomatic" oil tanks.
Could this tranny have been swapped? I've added a pic of the motors serial number if someone could help me identify it.
http://forums.pelicanparts.com/uploa...1385736697.jpg
http://forums.pelicanparts.com/uploa...1385736752.jpg
javadog 11-29-2013 07:25 AM
Yes, the transmission and other parts could have been swapped. I think the 902/1 was a 5 speed used during the SWB era, maybe around 1968. Your car should probably have had a 911/01. Yes, it used a pull-type clutch.
JR
maresdesign 11-29-2013 07:31 AM
Here are pics of the clutch and flywheel.
http://forums.pelicanparts.com/uploa...1385738955.jpg
http://forums.pelicanparts.com/uploa...1385738993.jpg
NOTE the holes along the outside, is this stock or a modification done to lighten it? Vent it?
http://forums.pelicanparts.com/uploa...1385739059.jpg
Bob Harriman 11-29-2013 07:33 AM
902/1 is a 911/912 with gear ratios AFMSX for MY years 65-67. The 902/01 is a four speed for a 68 912 with gear ratios AHQX
maresdesign 11-29-2013 07:48 AM
Ok, Thanks guys. Further research shows any 911 or 914 6 bolt 215mm flywheel will work.
Anyone know anything about the motor's serial number?
javadog 11-29-2013 07:49 AM
Fairly early production 71E targa motor.
JR
maresdesign 11-29-2013 07:54 AM
JR
Good to know since it is a Targa and a 71. 2.2 Liters is what I understand.
javadog 11-29-2013 08:13 AM
Yes, 2.2 liters.
JR
Trackrash 11-29-2013 10:23 AM
I have a '71 trans out of my E sitting in my basement. PM me if you are interested.http://forums.pelicanparts.com/uploa...1385749361.jpg
pors1968 11-29-2013 11:53 AM
65-68 5 speed and clutch and flywheel. you will be better whith 70-71 trans diff is bigger and you get more clucth 225 .But clutch flywheel bearing are more expensive.
maresdesign 12-02-2013 07:12 AM
I am going to keep this tranny in my 911, I like the gearing and the shift pattern suits my driving style. Thanks everyone.
ckrause 12-21-2013 08:16 PM
Don't know if you acted on this, but a 902/1 is a 5 speed trans from a '65-67 912...
902/1 32 5 11:34
A 18:34
F 22:29
M 25:26
S 28:24
X 7:31
Simplified 220 001-
221 721
(to 26 Jul 65)234 001-
238 942 standard except USA/CDN,
'65-'67 model years Diagram
