-   -   High idle after engine warms up... (http://forums.pelicanparts.com/porsche-911-technical-forum/78446-high-idle-after-engine-warms-up.html)
hobieboy 08-23-2002 12:09 PM
Hi,
I run into a small problem that really bugs the h*** out of me.
After the engine warms up, AND you drive it for a while. After I remove my feet from the accelerator (say stop at a light), the idle will most of the time go from the normal ~850 to around 1300rpm.
It might stay there for a long while then drops back, or sometimes it will just stay there.
I though it might be a sticky throttle linkage, but it seems to return to normal position everytime.
Any thoughts?
thanks...
john walker's workshop 08-23-2002 12:42 PM
below the intercooler is a deceleration valve. the large round gold thing. remove the small hose from the middle of it and plug the hose. then see if it makes a difference.
Targa77 08-23-2002 02:01 PM
John, my car does the same thing. Can you permanently bypass this valve?
dean 08-23-2002 06:40 PM
Yes you can get rid of the decel valve if you want.
RarlyL8 08-23-2002 06:45 PM
What is the effect after elemination of the decel valve?
What function does it serve in the stock application that is not needed by the enthusiast?
dean 08-23-2002 06:54 PM
I think the decel valve was put on for emissions. With the valve removed you idle will go down to normal much faster. Like a car should.
beepbeep 09-11-2002 07:33 PM
1 Attachment(s)
Is this decell-valve???
RarlyL8 09-11-2002 07:51 PM
Yes, that's it.
Mine is history. We'll see how she runs without it.
Victor 09-11-2002 08:52 PM
Guys, I take it this is the same or similar setup on an NA 3.2? Mine suffers similar symptoms.
Vipergrün 09-11-2002 09:29 PM
JW et al,
I recently unplugged the decel valve on my 80SC. I notice a bit of popping on decleration, I assume this is now considered normal? Also, some folks refer to *smashing* the decel valve a few mm to cure the high idle problem. Is there an actual procedure to do this?
TIA
-Brad
80SC
Jocke 09-11-2002 11:48 PM
Allright this was really interesting!
If I want to unplug the decel valve should I just plug the tubes or should these be connect together so the flow passes by?
/J
dean 09-12-2002 07:20 AM
If you want to take the decel valve out you should plug the openings, not connect them together.
Jocke 09-12-2002 08:06 AM
OK! Thanks!
But the smaller tube "on the decel valve"must be plugged?, have I understand it right then?
/Jocke
beepbeep 09-12-2002 08:35 AM
Is it enough just to disconnect the middle-hose on the picture and plug it w/o removing whole valve and plugging two hoses behind?
dean 09-12-2002 02:36 PM
Unless your valve is blown. Then you have to take out the unit and plug the ports. I would take the whole thing out anyway. It cleans up the engine compartment and saves about 1/2 lbs. Woo-hoo
beepbeep 09-12-2002 05:36 PM
Hmmm... :) I heard stories of flames belching out on high-rpm lift-off when deccel-valve is plugged...
True?
dean 09-13-2002 05:14 AM
I wish I had flames. It doesn't happen on my car. The only thing that I notice is that the idle returns like it should and the exhaust burbles alot.
