-   -   where does this wire go? (http://forums.pelicanparts.com/porsche-911-technical-forum/784804-where-does-wire-go.html)
archtech 12-01-2013 02:03 PM
Quick question... after valve adjustment, oil change, plugs change, and about to change points, decided to just try starting the car... did not fire up.. just cranked... i noticed a loose wire and I have no idea where it goes. here is a pic... is it a ground? will the car run without it hooked up? looks like its a black wire. car is a carbureted 2.2 911t thanks!
http://forums.pelicanparts.com/uploa...1385935294.jpg
HarryD 12-01-2013 02:07 PM
Is there a spade lug on the side of the distributor that is missing a wire? This may it.
jrbennett 12-01-2013 02:07 PM
It should connect to the distributor, it goes to the same connection as the black/purple wire.
archtech 12-01-2013 02:10 PM
it looks like the black wire is coming from the 3 pin Bosch CDI... wheres it plug into?
archtech 12-01-2013 02:11 PM
spade is broken off and stuck inside the female end... have to yank it and get another male spade
archtech 12-01-2013 02:15 PM
yup... i found the busted end at the end of the purple black connector. thanks everyone!
timmy2 12-01-2013 05:18 PM
571-619441 is the part number for the correct double spade connecter from Mouser.com 13 cents each. :)
