front swaybar help
I am attempting to put in my underbody sway bar and I am having quite a fight. This is a real B?$#@h. Anybody have any method that may keep me from killing my cat with something flying?
Thanks |
......I had jackstands under the torsion bars front mounts,..
while the rear bushings on the swaybar unmounted, I put a floor jack under one of the A arms and jacked it up alittle bit at a time untill I found the angle where the swaybar will slide into the bushings. if i remember correctly the wheels were really way offset. If this doesn't work, I will pull out the factory manual and see what they say about it. Hope this helps Tim in Sac |
After last nite's cussin', it slipped right in this morning. It is amazing how getting away from something helps one's perspective the next day!
| All times are GMT -8. The time now is 07:16 AM. |
