-   -   Brake pad sensor wire delete ?? (http://forums.pelicanparts.com/porsche-911-technical-forum/784820-brake-pad-sensor-wire-delete.html)
SiberianDVM 12-01-2013 02:23 PM
As part of my wintertime refresh on my track car, I'd like to remove the brake pad sensor wires I no longer use. Previously I had made jumpers for each wire so the light would not come on. Now I want to remove the wires or at least make them invisible.
The fronts were easy: I just pushed the wheel well grommet into the space next to the gas tank and filled the holes with metal plugs.
The rears appear to be more challenging. I have the trailing arms removed for bushing replacement with monoballs, and the wire seems to disappear up in the nether regions under the rear seat. Does it exit inside the tunnel or is it the paired wire just above the shifter coupler plate?
