ASE Master
alfadoc's Avatar
Thunk
On my relatively newly acquired 80 SC, there is a deep thunk emanating from the back when driving on bumpy roads. Reminds me of what a car that has suspension mounted to a subframe (Mercedes) sounds like when a subframe bushing is going bad. Any suggestions as to beginning diagnosis would be greatly appreciated.
1989 944S2 (sold after 11 great years)
1980 911SC Weissach (bucket list car)
1975 914 1.8 (future restoration)
1993 968 Coupe 6 speed (new acquisition)
Old 12-02-2013, 02:58 PM
I would rather be driving
jpnovak's Avatar
Check the short list:
spring plate bushings. If old, they are likely cold-flowed to the point where the outer cover is riding on the spring plate.
Sway bar bushings - are they still good?
Sway bar mounting points. These are known to crack and will clunk afterwards.
Old 12-02-2013, 03:09 PM
pors1968's Avatar
faulty sway bar link or loose upper shocks and check cv joint if bolt tight.
Old 12-02-2013, 03:43 PM
1987 Carrera
+1 on the sway bar especially if you hear the Thunk when turning.
Ace123
1987 Porsche 911 Coupe
Old 12-02-2013, 04:06 PM
ASE Master
alfadoc's Avatar
Thanks all, I'll report back my findings.
Old 12-02-2013, 05:45 PM
schumicat's Avatar
also check motor mounts.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 12-02-2013, 05:51 PM
