-   -   Is this the way a 915 operates? Or something else? (http://forums.pelicanparts.com/porsche-911-technical-forum/785157-way-915-operates-something-else.html)
Sicklyscott 12-03-2013 11:55 AM
Hi -
I've been DD'ing my 1980 911 for the past 2 weeks while my regular car gets repaired. I've been noticing some inconsistancies in the shifting effort of the transmission plus a few grinds here and there. I'm trying to understand if this is just normal 915 operation or if I need to adjust the clutch (or something more serious!).
Here are the symptoms:
- 1st gear can sometimes be very hard to get into. When faced with this problem I usually have to let the clutch out in neutral then push it back down and pop it in first. Sometimes it slides into 1st, sometimes there's still a struggle.
- Downshift from 5th to 4th to pass on the highway always produces a grind but when cruising on the street at low speeds it'll slide in.
- Sometimes 3rd or 2nd will get stuck in gear and take a lot of effort to get the selector out of gear.
I believe there was some trans work on the car in the past with some replaced syncros but i don't remember what the service history said exactly. This car is new to me and it's the only 915 experience I have.
Any help would be appreciated!
-S
redridge 12-03-2013 12:12 PM
sounds like you have a lot of slop on the shifter... I would look at the all the shifter/coupler bushings. Driving a nice 915 is nothing like you describe.
javadog 12-03-2013 12:14 PM
The first thing I would do is adjust the clutch and measure the cable release travel.
JR
James Brown 12-03-2013 12:15 PM
i would start with the shift linkage, make sure all the bushings are in good shape and the coupler has little or no play. Adjust the shifter throw. then check that the clutch is adjusted correctly. If all is good, then yes the transmission might need rebuilding. but the inconsistencies seem to point to linkage slop/adjustments. also, transmission mounts can cause problems shifting.
Josh D 12-03-2013 12:16 PM
Are you clutching all the way to the floor before changes? Are you allowing a slight pause in nuetral when going from one gear to the next? Are these symptoms when trans is cold, or all the time? What kind of RPM do you normally shift?
Before trying to diagnose any trans problem with these cars, make sure all the shifter related bushings are in good shape, clutch cable is adjusted, and shift coupler to trans is adjusted.
Once these are ruled out, then you can start to diagnose problems with the trans.
yelcab1 12-03-2013 12:40 PM
1. Adjust clutch cable travel.
2. Adjust shift rod bushings at the tunnel access port
3. Inspect gear oil for metal pieces
4. Inspect synchros.
In that order ... less to more money ...
redstack 12-03-2013 02:24 PM
Pretty much describes all the symptoms of my new to me 84. I had expected that it was the shift linkage. So thanks for confirming my hopes.
I must say that the 5-4 downshift grind, is the most disconcerting. I sure learned to be very careful on that one.
wannaporsche 12-03-2013 02:51 PM
The upper gear behavior you're experiencing sounds odd to me, but your 1st gear sounds like it works just like mine does:
I don't know if you're moving when shifting into 1st, but in case you are not this info helped me...
I read recently (in a 915 Zimmerman (?) post -- can't find it now) that 1st gear is built to be "downshifted into"-- meaning it works best to engage the gear while you're still moving and the tranny has some spin left that can engage the synchro.
I now find that if I finesse the shifter into 1st as I slow to a stop (traveling at or below 10 MPH) it slides into 1st beautifully every time. 1st does not like it if I come to a full stop in neutral and then once stopped try to shift into 1st gear because the gear is sometimes blocked…which is really frustrating.
My 2c
Cherry Bomb 12-03-2013 03:18 PM
Coupler Whisperer, shift bushings and trans/engine mounts cured 90% of my 915's sloppy performance. I am replacing the clutch cable and related wear items next since the pedal is at the top for action. Also a pedal cluster rebush/restore and...and...and...oops I slipped!
Good luck and have fun doing it!
porsche moose 12-03-2013 04:00 PM
my 911sc did it to went with Coupler Whisperer and trans/engine mounts change trans oil i love kendal 80-90, shifs like butter
Peter Zimmermann 12-03-2013 04:00 PM
First, you should never be in 5th gear at speeds below 60 mph. The 5 to 4 downshift with a grind indicates that you have a linkage problem, either adjustment, or bushing wear, or... If you choose to do this type of work yourself there is much to know/learn, but it can be done. The remainder of your issues can be trans related, or driver technique.
To sort out the technique part always use a two-part shift (the search button is your friend), try to make the majority of your up-shifts between 3500 and 4500 rpm until you start to develop a feel for how the car likes to be driven. Don't do what upsets the car, you must adjust to it; it can't adjust to you. Another poster mentioned that he uses my preferred method of using 1st gear; I always downshift my own 915 into 1st at very low speed, less than 10 mph, and remain in gear while at a stop sign or traffic light.
Getting "stuck" in gear is extremely unusual, and could be oil related. It could also be a problem related to the last trans work. It would be very helpful if you can find your service records so we can see what's been done to the car; i.e. clutch cable replacement, trans oil change/oil type/viscosity/dino or synthetic, etc. It would also help to know if the car has been professionally maintained.
When you drive the car try to not let the revs drop below about 2600-2800, and don't use more than about 4500 for steady speeds. Take your time and learn the car. If it's possible, locate a shop in your area that understands the 911SC, and have their tech drive the car and evaluate it regarding your concerns. And find those service records!
911pcars 12-03-2013 04:15 PM
80% of the 901/915 gearbox issues fall on the previous owner who may not have shifted properly. Porsche synchromesh isn't as durable as in other vehicles/later Porsches. Learning and/or practicing double clutching will extend the remaining synchro life.
Sherwood
strikee 12-03-2013 05:51 PM
I have just replaced my rear shift linkage (eds) / tunnel and cup bushings.
I also replaced the engine and trans mounts.
After an exact adjustment the shifting is much improved.
If you are grinding 5th to 4th you are catching reverse (i think). Again this is an adjustment problem.
I still shift into 1st on the roll up to lights and its slots in nicely.
I am learning to not rush 1st to 2nd but its hard when you are showing off the awesomeness of acceleration.
Ed
TargaHenry 12-03-2013 06:49 PM
I have an 84 with a 915, and I find the above posters to be right on. My car shifts like velvet, and now that I know the car a little better, I know how little accelerator it takes to make the shift perfectly smooth, with a nice earthy power pouring out of each successive gear. Frankly, after the other sticks I have owned, I am surprised by just how smoothly this car shifts.
Sicklyscott 12-03-2013 07:15 PM
Sounds like I'm driving this car all wrong! Many of my up shifts are before 3000 rpms!
During regular driving however it up shifts fine, I do take my time with it and never slam it in.
I'll take a look at my records tonight and report back.
Sicklyscott 12-03-2013 07:57 PM
Ok, here's what I can find/read:
- clutch cable done in 3/2012
- Rennshift purchased in 3/2011
- 1st and 2nd syncros replaced 12/2002
- weltmeister short shift kit installed 12/2002
- clutch replaced 7/2002
What I do not see in all the paperwork is trans fluid replacement, even with all the oil changes. And I don't see anything about bushings.
I can estimate that I 2002 when a lot of the work was done the car had 46k miles on it. It now has 80k miles.
I guess first thing is first, change the trans fluid. While under there ill check for slop in the linkage.
rbogh901 12-03-2013 08:10 PM
I find I do this easily and butter smooth just before stopping, like 2mph. The POs of my car probably did not so I prefer to go real easy on the 2-1 shift, no angry shifts are ever likely necessary into first. Once in first and at a complete stop I can easily go into neutral and let the clutch out until time to slip back into gear. As long as the car does not move the transmission will go in and out of gear as many times as necessary and I do not have to keep the clutch depressed through painfully long waits.
javadog 12-03-2013 08:10 PM
Check the clutch adjustment and travel first. Then have a look at all of the shifter bushings, in the tunnel, not under the car. Consider losing the Weltmeister kit. Then you can worry about the trans fluid. It's not the problem.
JR
boyt911sc 12-03-2013 08:15 PM
Learn to drive this car........
Sickly,
A fellow PP member came to visit me requesting assistance for a transmission work because he was having the things you're experiencing with his 915 transmission. He replaced all the linkage bushings and shift coupler to no avail. I took the car for a drive and noticed the difficulties shifting gears and grinding during down shift. Asked him to leave the car and did the following:
1). Re-adjusted the clutch cable travel.
2). Re-align the transmission coupler setting.
3). Drained gear oil and put in Swepco 101.
A week later he came to test drive the car and noticed the big improvement. He thought I replaced the synchros and did some transmission rebuild!!!! Told him just adjustment and maintenance were needed plus learn to drive a Porsche. He was shifting like driving a Honda Civic and advised him to rev much higher to 3000 plus or higher RPM during up shifting and a short pause in between gears.
Tony
mcfadyenpb 12-03-2013 08:19 PM
I would look at the all the shifter/coupler bushingshttp://netkios.com/12g.jpg
71scgc 12-04-2013 05:47 AM
Put it in 2nd before shifting to 1st at a dead stop.
My shifter/trans is sloppy too.
Carter
Groesbeck Hurricane 12-04-2013 10:50 AM
I would highly recommend you check your shifter bushings in the tunnel. No need to crawl under anything, it is a very straight forward operation. They are inexpensive and wear with age. When they are loose/disintegrated you will experience some of the same symptoms. Inexpensive and you can do it at home in very little time.
I would suggest you double clutch before going into first. And as is mentioned above, go into second then drop into first.
NYNick 12-04-2013 01:03 PM
I'm not sure why ANYONE would shift into 1st gear above 10 MPH...
frannyB 12-04-2013 01:08 PM
Hi there,
I just installed the Seine shift gate and it really helps a lot! I had the same issue with getting out of 5th and then 4th is nowhere to be found... The Seine spring thingie spring loads the shifter in to the 3-4 plane and helps prevent a super bad 5 to 2 shift. I also replaced the coupler (the neat red one from Pelican has set screws to remove the pivot shaft) and all the bushings and adjusted the clutch AND the clutch stop in the floor board as per the service manual. Things are much better now. Oh, I also replaced all four engine/tranny mounts. Not expensive and easy to do. If all else is good and it shifts better straight than in turns, it could be your mounts.
I do still have the occasional difficulty getting from 1st into 2nd, mostly when the tranny is warm (weird), but other than that it is pretty smooth now. I also replaced the fluid with new dino oil.
Lot of moving parts in all that so just hit them all and it should improve greatly. Oh, and by all means, wind the thing up a bit more. Lugging the engine isn't as bad as it used to be, but it is still not good. At the very least, you are pulling the same power, but I think the oil system isn't putting out as much due to the lower RPMs. I would never dare shift when the little up arrow tells me to. Plus it sounds really awesome past 4000K!
Good luck with your journey,
Franny
jmcn3rd 12-04-2013 01:37 PM
Hey, I couldn't tell if you had welt ss kit or Rennshift already installed, by I bet if you replace the trans fluid with swepco, replace your bushings (2 under shifter and also coupler ones in rear, and get a WEVO shifter, you will be a much better place. That is what I did and it was night and day. There is a neat little adjustable reverse block off pin that helps keep you from hitting reverse on the way down from 5 to 4. That always really bothered me but does not happen anymore. I occasionally touch 3rd to let me into first gear, it is odd but it works. I don't think your symptoms are that strange, but they do seem to be saying you are out of adjustment and probably have worn bushings. I think everyone already answered these same things but thought I would add since this is what I did to clear up my shifting. Oh forgot, also did WEVO semi-solid engine mounts and OE sport trans mounts, old ones were worn so these keep it tight.
Peter Zimmermann 12-04-2013 04:51 PM
http://forums.pelicanparts.com/porsche-911-technical-forum/524583-swepco-transmission-fluid-question.html?highlight=swepco+trans+oil
Busta Rib 12-06-2013 09:23 AM
Scott, I just found this thread. Sorry to hear you are having issues with the shifting. First, I want to encourage you to try the suggestions on how/when to shift. I never had these issues with the car that you are having. First, the 915 doesn't like to be short shifted. Get the revs up over 3500+ before shifting. Second, you can not speed shift the tranny. Doesn't sound like you are, but a slight pause before engaging your next gear makes all the difference. The coupler and bushings were all swapped out when I installed the Rennshift shifter. They should not be the issue. Perhaps you can try adjusting the clutch cable. Also, I always depressed the clutch pedal fully before shifting. Overall, if you take these steps, the car should shift smoothly and engage all gears properly as it did for me. Call me if you want to discuss.
Jim
PS: make sure you use the reverse lock-out lever when you are driving on the freeway. It helps eliminate potential grind on downshifts to 4th for passing.
911pcars 12-06-2013 11:59 AM
Never shifting below 3500 rpm is a conservative blanket statement which may apply in most active driving situations. However, there's nothing wrong with shifting below 3500 rpm as long as you avoid putting a load on the engine (excessive throttle opening at low rpm @ low vehicle speed). One can coast at engine speeds below 3500; level, downhill or uphill with no stress on the engine.
Sherwood
