Is Bosch Universal Oxygen Sensor Installation Video Correct?
It is very hard to believe the electrical wires can let air go through: http://youtu.be/3Yt6Lg0oU58 __________________ This post was auto-generated based upon a question asked on our tech article page here: |
This has been discussed many times before here at Pelican HQ. I've written five books on Porsches and BMWs, and the fact of the matter is that I still don't know for sure. The goofy posi-lock system that BOSCH has for these connectors seems a bit odd to me. In general, the O2 sensors are supposed to be water-proof, meaning that they have to work submerged in water. So, the air-reference signal that the sensor needs to measure O2 has to be gathered through the connector itself. I'm not sure if soldering by itself is the issue with not having a proper connection, or whether it has to do with the fact that people seal the connection with tape and/or heat-shrink tubing. I would agree that soldering by itself would probably not cause a problem. The act of covering up the soldered connection is what causes issues, I believe. This is just my opinion - I'm not 100% sure. In all of the books that I've written, I recommend that our customers stay away from these generic sensors and instead use the proper OEM BOSCH ones with the proper car-model-specific connector installed and attached at the BOSCH factory.
- Wayne |
The O2 sensor uses a supply of reference air and Bosch is adamant that this small amount of reference air is replenished via the wiring. If the body of the sensor is sealed it has to pull air from somewhere. I figure they might know what they are talking about even it I don't fully understand it.
Crimp, don't solder and use heat shrink tubing or use the supplied Bosch connector. Can't go wrong with the factory sensor but plenty of people, myself included, have used Bosch part number 13913 (1986 Ford Taurus). Cut the ford factory connector off the sensor and splice it into the factory Porsche harness. If you stagger your splices you won't end up with a lump in the line and you can reuse the factory heat sleeve. I've got around 10k trouble free miles on this set up. -J |
Note that the OP is referencing a Bosch video that clearly states the AIR must pass through the ELECTRICAL WIRES to make the O2 sensor work properly. Pffffft. That is hogwash. Even though JAR2003 refers to reference air, this is impossible. Prove me wrong....... http://forums.pelicanparts.com/uploa...1386115337.jpg |
Anyone know how to find sensors based on connector type and wire length? The OEM Bosch sensor wires were not long enough when I installed headers on my '84 3.2, and it would be nice to avoid a splice (BTDT).
The turtle is pretty scary, right? |
For the sensor to work correctly, it must draw clean air down to the sensor through the air gaps in the stranded wire. If you solder the wires, the solder will fill the air gaps in the wire and the sensor will not work correctly. I am just going to hang myself. Oxygen Sensor General Information, Testing, and Replacement |
Crimped joints are best. However properly soldered wires are fine. The problem is most people do not heat the wire enough and create cold solder joints.
OK, what's the deal with these universal Bosch O2 sensors, then? Should we just cut off the factory connectors and use the universal ones supplied in the kit?
Are they really suggesting that if we were to solder the sensor wires onto the factory connector, we would choke the sensor of reference air? This really belongs on snopes.com. |
That documentation is downloadable from their web site on the internet, linked/referenced in at least 3 threads on the 911 forum. And quoted above by Bob. I first read found this information myself in 2003 on F.R. Wilkes' (a Pelican, BTW) site in 2003. Sure, there's lots of people all over the interwebs saying "are they really serious" and saying that Bosch don't know what they're talking about. They must be right, there's so many of them. I guess Bosch must've just made it up. Maybe they needed to sell more connectors or something. |
I think I'll just roll with the universal connectors supplied.
But it would be cool to do some myth-busting and actually measure the O2 signal with different wire/sheath tampering/jiggery-pokery. |
I probably put the shrink wrap tube on it but that is a DIY guy with a blow dryer. Did it really seal to the point of making the solder joint "shunt" the reference air. There were "open" wire strands upstream and downstream of the joint. Maybe if I sealed it perfectly, then drove up 7,000 feet above sea level, the "old" reference air would indicate more oxygen than true. On the other hand, this stuff is witchcraft so I ain't messing with it. Crimping or the fancy half hour to install connectors (4 wire) |
From this thread: http://forums.pelicanparts.com/porsche-911-technical-forum/497025-o2-sensor-connector-2.html
And my post #56: http://forums.pelicanparts.com/porsche-911-technical-forum/497025-o2-sensor-connector-2.html#post8259941 Quote:
From my post #58 http://forums.pelicanparts.com/porsche-911-technical-forum/497025-o2-sensor-connector-2.html#post8261091 Quote:
This would certainly seem to be supported by the statement in the Bosch "Testing 3/4 wire lambda sensors document that says Quote:
And. again from that #58 post: http://forums.pelicanparts.com/porsche-911-technical-forum/497025-o2-sensor-connector-2.html#post8261091 Quote:
That statement telling you not to solder the wires is from Bosch's installation documentation for the part under discussion here - the "Universal" sensor. Seems pretty conclusive to me - but believe whatever makes you happy. |
I soldered the wires when I lengthened them to work with my B&B headers. Seemed to work fine.
I have SSIs and a new, unmodified OEM sensor going on after my engine rebuild, so it will be interesting to see if there is a difference. |
There is no "force" that pushes/changes out the air. It's odd to a layman. |
Except it's not that simple. What seems, just from looking at it, to be an electrical lead with a plug on it is regarded by Bosch engineers as a PTFE formed hose comprising a reference air volume with a permeability within guaranteed limits.... :D For example, the Bosch reference document for the LSU 4.2 planar http://wbo2.com/lsu/Y258K01005e03mar21eng.pdf gives: Quote:
This document based on the Bosch planar wideband http://wbo2.com/lsu/oxygen13-17.pdf is a little more detailed - but it's the same tech. |
OMG - I read through the first link.
They are serious about this stuff. Thanks. Cripes, even talked of bend radius in the PTFE hose. |
| All times are GMT -8. The time now is 09:48 AM. |
