-   -   993 GT2 conversion : need your help (http://forums.pelicanparts.com/porsche-911-technical-forum/785328-993-gt2-conversion-need-your-help.html)
marc33 12-04-2013 09:14 AM
Hi all
One of my friend is thinking of modifying his 993 C2 to GT2.
When calling one supplier of the bodykit (D Moris in France), he got a strange reply : you need first to install the rs/turbo back flares to be able to install the GT2 extension flares...
So my question is if anybody has experience with this conversion and if he needed to first modify the back flares to wider model prior the GT2 extension installation
Also if you are aware of any supplier who has the bodykit for "standard flares"
Thanks in advance for your help ;)
Rgs
Marc
Bill Verburg 12-04-2013 10:46 AM
Originally Posted by marc33 (Post 7789226)
Hi all
Rgs
Marc
993 GT2 was based on the wide body 993S/turbo, so apparently was the body kit in question, the 993S/turbo has quarters that are ~1" wider on each side than a 993 n/b.
The 993 RSR on the other hand was based on the 993 n/b had has flares that are similar in appearance to the 993GT2 bolt on flares so perhaps that would be what to look for.
marc33 12-05-2013 04:04 PM
Hi Bill
Ok for the wider flares but we thought that as we have to cut it anyway to install the GT2 extensions, to have normal or wide flares was not important as it's cuted...
Bill Verburg 12-06-2013 07:13 AM
Originally Posted by marc33 (Post 7791772)
Hi Bill
You only cut less than 15 or so cm around the wheel edge, the base fender is still there
here are the oe rear flare part #s
993RSR based on a n/b 993
993.504.399.30 & .40
993GT2 based on the w/b 993turbo/S
993.504.319(&20).80
marc33 12-06-2013 12:43 PM
Thanks Bill ;)
