exhaust set up
Redridge, The Cat converter I chose was made by a quebec Canada firm called Maxspeed motorsports 1-855-466.2977. I chose a 100 cell Cat because I found that a pre muffler I had previously had quite an offensive smell (M&K) .The cat is of excellent quality, only 100 cell ...virtually free flow. Fab speed might have a similar product.
The muffler is produced by Monty mufflers, an Australian small SS MFG. that produces custom made mufflers for Porsches see Monty Mufflers - porsche mufflers stainless steel australia USA - hand, fabricated, heavy, gauge, 304, flanges. Monty has been doig this for the last 30 years and his products are a piece of art in quality and view. The sound is second to none, reminds you of a nice v8 burble...I believe there is a u tube segment for a monty muffler....it is not cheap...probably about $1300...communicate with him by e mail...very honest and straight forward. The Steve Wong chip was set for such a configuration with 91 octane. Talk to steve and explain all of the above...he used to recommend Monty in the past... I hope this helps. |
This system is much more difficult to tune for all configurations and rpm and throttle position The first 911s w/ chip controlled engine management are the '84 Carrera 3.2s, these are relatively straight forward to tune for every possible configuration/rpm/throttle position w/i the systems parameters. |
A cat or pre-muffler when combined with a single in single out main muffler will produce a nice note that is not too loud.
For the Carrera the pre-muffler / single in muffler combo performs as well as SSIs with a dual inlet muffler. The reason is primary tube ID sizing on the SSIs are a touch small for the 3.2L ports. |
| All times are GMT -8. The time now is 07:37 PM. |
