tlarocque's Avatar
Strange start issue in cold weather
Driving from SoCal to Seattle. Drive 380 miles today without issue. Stopped for lunch and when I went back out to get on the road, car wouldn't start. Has juice but nothing turned over. Called tow company but with one last try (clutch pushed all the way in), fired right up. Drive another 170 miles, check into hotel, come back out and have same issue. I'm having a beer and hoping it starts when I get up in the morning but looking for thoughts, advice.
TIA!
Old 12-05-2013, 06:47 PM
porwolf's Avatar
I read similar stories here on the Pelican. Myself, I never had this problem. But I would guess the problem could be the solenoid that controls the power to the starter motor and pushes the starter gear into the flywheel gets stuck. A lot of people were able to get it unstuck by hitting the starter motor smartly, but not too hard, with a piece of wood like a baseball bat.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 12-05-2013, 09:19 PM
In maintenance phase
daniel911T's Avatar
Not meaning to hijack... but I'm just about to set out from Seattle in my 69 headed to mid CA. Wave if you see a white longhood going the other way!
I also happen to travel with hundreds of pounds of tools and technical books... so should you get stuck.... I think I could drop an engine on the side of the road if it came to that! I'm sure a stubborn starter or random relay is well within what I'm equipped to handle
PM me if you're in a jam.
Good luck!
-Dan
1969 911T (Getting a 72E heart transplant)
2004 Volvo XC70
Gone, but not forgotten:1971 Bug, 1978 Bus, 1982 Westy, 1996 GTi, 2000 Audi A4 2.8, 2001 Jetta Wolfsburg 1.8T, 2002 Audi allroad 2.7T, 2010 Jetta SportWagen TDi, and a couple of short lived 914s.
Old 12-05-2013, 09:23 PM
The Bavarian
TIA!
Either the starter switch in the dash board, the starter solenoid or a bad/corroded battery cable or ground. You may also check that the 14 pin connector at the back of the electrical console in the engine bay isn't loose.
- Manfred
'80 911 SC Targa black/black
Old 12-05-2013, 10:30 PM
muck-raker
kidrock's Avatar
the starter is probably the original Bosch, and is having a common "heat soak" issue. After the starter has cooled, it will start again.
A gentle tap on the solenoid will temporarily remedy this issue. A rebuild (or replace with the newer and lighter "hi torque" starter) is probably in your future.
Before you start replacing stuff, follow Manni's advice and check your battery connections, check and clean grounds at the trans and at the battery. If necessary, check the 14-pin connector as well.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 12-05-2013, 11:02 PM
T77911S's Avatar
good advice from the 2 above.
you should post the year. the 3.2's had more of an ignition switch problem than the earlier cars, but i dont think that is your problem.
most likely it is the solenoid, but you need to do other stuff first.
make sure all you major power connections are CLEAN. dont forget the grounds, and the body to tranny cable.
good fully charged battery
if you have an after market car alarm, those are junk and can cause the same problem.
check power on the yellow wire at the starter. i prefer a test light. compare the light across the battery to when it is connected to the yellow wire.
search my thread on rebuilding the solenoid and starter.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-06-2013, 03:41 AM
tlarocque's Avatar
Thanks for all of the responses. I think kidrock may be onto something as it fires right up after sitting for a while. If/when I arrive in Seattle I will have to look into all of the things mentioned.
daniel99T- I will keep an eye out for you! The drive has been fun but this morning we woke up to what you seen in the pic below (we are in Eugene, OR)... not my kind of Porsche driving weather so I think we're going to let the weather pass.
Drive safe!
1988 Carrera GP White
2010 GT3 Carrara White
Old 12-06-2013, 08:37 AM
muck-raker
kidrock's Avatar
you have to appreciate a starter that lasts 25 years. I replaced mine with the hi-torque about 4 years ago. The old Bosch had the same problem as yours. When I eventually pulled it, I noticed that the solenoid housing had a decent sized crack on it, probably from the prior owner banging on it.
Enjoy the snow up there, it only lasts a very short while. I'm down to 360 days before I relocate to the area permanently. I can't wait, it's one of my favorite places in the country.
STONE
Old 12-06-2013, 08:52 AM
