-   -   New Prototipo what else needed to install? (http://forums.pelicanparts.com/porsche-911-technical-forum/785681-new-prototipo-what-else-needed-install.html)
Bill Jennings 12-05-2013 09:36 PM
Hi All,
Just bought a new Prototipo I know I also need a boss kit but do I have to buy anything else to get the horn to function? The wheel comes with the standard MOMO horn push which I would like to change to a Porsche one but do I need anything else on top of the boss kit?
Cheers
Bill
WPOZZZ 12-05-2013 10:04 PM
You might need to make a short jumper to ground the horn.
Bill Jennings 12-05-2013 10:11 PM
WPOZZZ,
Cool I thought it needed a slip ring or something for the connection. I haven't bought the boss kit yet so unsure what is needed.
Cheers
Bill
WPOZZZ 12-05-2013 11:18 PM
It has been a few years since I've changed a wheel, but here goes. The horn button should have two tabs on it. One is connected to the original horn wire. On the steering wheel, you will have a slip ring with a tab. You connect the other tab on the horn button to this. If there is no slip ring, connect the jumper to one of the hub bolts.
