-   -   Not quite a Carrera script (http://forums.pelicanparts.com/porsche-911-technical-forum/785712-not-quite-carrera-script.html)
McLaren-TAG 12-06-2013 07:29 AM
I've had this idea for a while but decided to actually get it done, I'll be using it on my new helmet come spring. You're welcomed to it if you share my name. :D
Used this...
http://i1193.photobucket.com/albums/...psc2b438f3.jpg
to go to this.
http://i1193.photobucket.com/albums/...ps52e5fcc0.jpg
JAR0023 12-06-2013 08:21 AM
Well played. I like it. -J
ppickerell 12-06-2013 09:02 AM
My brother in laws Lemons Typ 3 VW has "carerror" on the side
rbogh901 12-06-2013 12:16 PM
Do you have a file that can be used to have these produced?
McLaren-TAG 12-06-2013 12:27 PM
No, the original I just pulled from Google images and then used that one as an edit starting point. A friend with a graphics business did it for me thinking it would be pretty easy since I needed only two letters altered but mentioned it was harder than he thought getting everything aligned.
He gave me various versions in a .eps file with a black negative space on clear background as well as an outline negative space in case I wanted to create the graphic in different colors.
McLaren-TAG 10-08-2014 07:19 AM
Finally got around to putting rubber to the road on this. I'm happy with the results.
http://forums.pelicanparts.com/uploa...1412777908.jpg
http://forums.pelicanparts.com/uploa...1412777924.jpg
