SWB pedal area
i am in the process of brining a '68 SWB back from the dead. I came from 356 land and have expertise with that model, not so much the 911/912.
What are the 3 threaded inserts for in the back of the pedals?
Old 12-07-2013, 04:30 PM
pors1968's Avatar
They are for somes relay .Emergency relay(option) hight low bean . You should have harness in this location
Old 12-07-2013, 05:00 PM
67 911 Targa
There are a couple of hazard light relays that mount there. Yours may have been relocated by a PO. It doesn't look like from the photo that the spade connectors are there on the harness any more.
Thank you!
I am using the orginal harness with modern fuse box with relays. So no need for these.
Old 12-07-2013, 05:48 PM
pors1968's Avatar
good luck and i think the rubber for brake hose are upside donw .
Old 12-07-2013, 08:01 PM
