M&K Muffler Strap 1985 Carrera
I just purchased a used M&K muffler for my 1985. Does anyone know if I can I reuse the stock muffler straps and bolts or do I have to purchase the M&K strap kit?
Thanks!
Old 12-06-2013, 04:51 PM
I was replacing an M&k on an 88 and even trimmimg the factory support could get only one on properly.
Bruce
Old 12-06-2013, 06:00 PM
Bruce
Are you saying that I will need to order an M&K straps? Thanks.
Old 12-07-2013, 06:26 AM
kkkarpuk's Avatar
The short stock strap worked on my 3.2. I received 2 straps with my 1/1 Carrera muffler but could only get 1 to work so I used the short stock strap as a second. Since my rebuild I have gone with 1 strap without issue.
Ken
Old 12-07-2013, 08:38 AM
Thank you for the answers!
Probably a long shot, but of course I'll try anyway.
What are the lengths of t-bolt straps I would need for the M&K 1/1 ?
Old 12-07-2013, 09:04 AM
kkkarpuk's Avatar
I believe the short stock strap is 22" and it fit fine.
Ken
Old 12-08-2013, 12:37 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Same problem with my M&K and Dansk.
I end up putting a piece of pipe (at the top) against the muffler to take the slack out.
Who Will Live... Will See
Old 12-08-2013, 03:55 AM
rfuerst911sc's Avatar
I have M&K mufflers on my 911SC and my 914/6 GT and on both I'm using stainless steel band clamps from a hardware store. Using two per. No problems with this setup for over 5 years now.
Old 12-08-2013, 04:47 AM
After some searching looks like M&K is using standard T-bolt straps from McMaster.
Maybe I should go that route and order some before my muffler arrives.
I sent an email to M&K to get the diameters and part numbers of the T-bolt clamps. Unless someone here would happen to know?
Old 12-08-2013, 06:18 AM
For future reference:
M&K replied:
The Carrera single inlet uses a 6.25" (compressed) strap on the driver's side and a 6.75" (compressed) strap on the passenger's side.
Old 12-08-2013, 07:51 AM
