-   -   Alignment needed after new Bilsteins?? (http://forums.pelicanparts.com/porsche-911-technical-forum/78625-alignment-needed-after-new-bilsteins.html)
les-paul man 08-25-2002 02:01 PM
on 83sc, I'm replacing stock Bego shocks with 4 Bilsteins...do I need to have an alignment afterwards?
Chris Lovell 08-25-2002 02:11 PM
I replaced my Boges with Bilsteins. No alignment needed for me.
les-paul man 08-25-2002 03:06 PM
thanks Chris...that's good to know, since I plan on installing the shocks after the tires are on and the car aligned.
gr8fl4porsche 08-25-2002 05:16 PM
Switching to Bilsteins caused my ride height to go up about an inch. Had to drop it back down by reindexing rear torsion bars and simply lower the front with the bolt adjustment. All of which requires a realignment.
Do the shocks and struts first then the alignment.
Wayne 962 08-25-2002 07:57 PM
Since you have to remove the top of the shock towers from the car, you will indeed messup your camber settings, and should have them readjusted...
-Wayne
jwill911 08-25-2002 08:22 PM
You don't necessarily upset the camber/caster adjustment at the top of the shock tower to replace the struts. But if you replace with a strut/shock that changes the suspension geometry (ride height) at all it will likely chew up your new tires. BTDT wasted a set of front tires in ~5K miles after I put my new Koni adjustables in my `87 without getting an alignment. Don't believe it when someone tells you it won't need an alignment.
jw
les-paul man 08-25-2002 08:47 PM
-Wayne
hey, you guys didn't tell me I had to remove the top of the shock towers when I ordered the parts....I was told that the Bilsteins should fit where the Boges were without a problem.
:confused:
cab83_750 08-25-2002 10:37 PM
My height also increased a lot -- enough for me to get the ride ht readjusted!!!!
cary 08-26-2002 04:01 AM
I'm with Randy. Mine went up about 1 inch in the back.
