mikequig's Avatar
Plug wires coming loose
Since going to solid motor mounts on my 911 track car, my 3-liter will occasionaly "spit out" a plug wire from the spark plug causing a misfire/loss of cylinder. I have done a quick and dirty remedy using tie wraps but I have heard of a clip which can be mounted to the valve cover bolts. Does anyone have any ideas on this remedy or others. My wire set is otherwise in great shape.
Old 08-25-2002, 10:41 AM
Senior Member
Doug Zielke's Avatar
Re: Plug wires coming loose
Originally posted by mikequig
.........I have heard of a clip which can be mounted to the valve cover bolts.
Yep. I bought my set from The Racers Group.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 08-25-2002, 10:49 AM
stormcrow's Avatar
Sounds like your spark plug is not pushed on the plug all the way. I had the same problem and found out that I wasn't pushing the wire on hard enough to hear the pop.
Old 08-25-2002, 04:54 PM
