fuel mixture setting
I suspect the oscillating idle on my 81sc might be due to a too rich mixture setting.
I say this because the shop that set it adjusted the CO % at around 1.5%.
Looking at my spec. booklet, I noticed that for the 78 and 79sc's (without the O2 sensors), a setting of 1.5% is OK, but that mine should be btween .4 and.8%. I also understand that the reading should be measured without interference from the Cat or the O2 sensor.
I will be hooking it up to a gas analyzer later in the week, my question has to do with disconnecting the O2 sensor before testing/setting. If I simply remove the control module relay, will that fully disable the sensor or do I need to disconnect it from the sensor itself?
Thanks for any insight!
Old 12-11-2013, 05:08 PM
emac's Avatar
Just unplug the wire from the oxy sensor. Located below the CID box
Ernie 81sc
Old 12-12-2013, 05:03 AM
OXS replacement.......
Ernie 81sc
If your OXS connector is starting to crumble or disintegrate, this is the best time to replace it. A PP member by the screen name Louie85 (?) makes an excellent replacement part. Bought a few of them in the past and could never been more satisfied.
Tony
Old 12-12-2013, 07:18 AM
Thanks... The O2 sensor is new, but I will keep our PP member in mind.
Anyone ever reset the 02 sensor counter? Is it necessary/recommended?
Old 12-12-2013, 10:18 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Do not remove the relay. Just unplug as noted.
O2 - I reset set that little pig every time I have a big gauge out.
1981 911SC Targa
Old 12-12-2013, 02:15 PM
