-   -   Horn upgrade wiring (http://forums.pelicanparts.com/porsche-911-technical-forum/787101-horn-upgrade-wiring.html)
OttoBob 12-15-2013 10:31 AM
Horn upgrade wiring
I just purchased the horn upgrade from our host, and can't figure out how the wiring connectors go together. It did not come with instructions, so I thought I would ask on this message board before I gave them a phone call. I'm hoping somebody who has done this procedure can give me an easy explanation. Thanks!http://forums.pelicanparts.com/uploa...1387135862.jpg
javadog 12-15-2013 11:54 AM
Just a guess, but... try cutting the old connectors off of the horn wires. Crimp on the new terminals (don't forget the yellow bits), insert them into the new plugs and plug them into the horns.
Push the horn button to test the honking.
JR
OttoBob 12-15-2013 04:13 PM
Javadog...No way do the yellow things fit over the new terminals. Thanks for your idea, however.
2stroke 12-15-2013 04:39 PM
Put said yellow things on wires before crimping on metal ends!
atcjorg 12-15-2013 04:50 PM
I would clip the old plug off slip the yellow seal over the wire strip insulation then crimp end on and push into socket
donporfi 12-15-2013 05:02 PM
The yellow things are seals to avoid water entering the contacts. It is a very tight fit.
javadog 12-16-2013 04:39 AM
In this order:
wire, yellow boot, terminal, plug, horn.
JR
VFR750 03-22-2014 12:10 PM
Has anyone actually figured out how to get the yellow seals on the multi-strand wire?
I read this post and still have no Idea were they go and how. They have a miniscule hole in them.
A picture would be helpful.
VFR750 03-23-2014 10:37 AM
I did a search and found the assembly instructions from the manufacturer. Turns out the little yellow seal is designed for a 0.9-1.4mm wire. Very small! The stock wire in the SC is ~3mm in diameter. And the hole that the seal fits into is 3.45mm in diameter. Math says stock 3mm wires do not fit the connectors. And 1mm wire looks too skinny.
Fortunately an intermediate wire size (1.8mm) will work. My solution to go between the 1.8mm to 3mm wire was to wire the plug with spade connections, so I could retain the factory connector. I am backwards compatible to original horns if so desired in the future.
Wire Sizes:
http://forums.pelicanparts.com/uploa...1395599376.jpg
Building the Plug:
http://forums.pelicanparts.com/uploa...1395599408.jpg
Installed:
http://forums.pelicanparts.com/uploa...1395599430.jpg
Hope this helps the next person.
