One thing I found that I can share with you now. I had bought an Actron meter to use in the dwell mode to measure duty cycle. I gave up on it after getting readings I knew to be wrong, and I mean way wrong. I verified this by attaching three things into a test setup I made for the workbench in my garage: a real duty cycle meter, an oscilloscope, and an inline DC ammeter. They confirmed that the Actron dwell meter could not be relied on to provide accurate information. An example is reading 20% duty cycle (yes, after doing the conversion) when everything else said 93%. This was my experience, others may have a different one. The d.c. meter I used, which I found to be dead on in every case, was one I've had in my tool box for years, but always used for other measurements, like voltage, resistance, rpm, and temperature. A SunPro CP 7680. Your AFR meter reading indicates (if it represents what voltage an O2 sensor might be putting out) a slightly rich mixture. I just hate to see someone else struggle with something I know was a problem for me. YMMV. |
That is only a statistical mass of one. However, that's all I have as a reference point. So I look up your SunPro CD 7680 unit. Actron owns it now......... I won't sleep tonight. |
Jim,
Wow that is interesting about the Actron unit. Thanks for sharing that. Now I'm worried about trusting that thing to set the AFR correctly. Bob and I talked by phone (thanks again Bob!) tonight and we made some progress. Here is what happened: - Bob suggested I disconnect the 12-pin connector and clean the pins. It didn't look bad but I hit it with a wire brush anyway. - I left the narrowband O2 output to the ECU (green shielded wire) disconnected but I hooked up the DVM. - New O2 sensor relay was plugged in. - The Actron dwell meter was connected to the green/white wire on the test port (and to ground). I started the car and the dwell read 16 on a 4-cyl scale. The DVM read .63 V so it's running rich. I was misreading the Bosch book. With a rich signal, the ECU sends less of a duty cycle. The less time the valve is open, the less fuel injected. To prove this, I grounded the green shielded wire and the dwell dropped to zero. I also heard a slight RPM change so that leads me to believe the ECU is working as it should. My next step was going to be to adjust the AFR a bit using the 3mm hex screw after I got off the phone with Bob. I turned my garage upside down looking for my long allen wrench set and couldn't find it. I finally decided to have a beer and watch Christmas Vacation with the kids. I'll run over to HF and pick up another long 3mm allen wrench tomorrow. The plan is to back the AFR down until the DVM reads about .45 V and see what happens to the dwell reading. It will also be interesting to see how it runs after another cold start tomorrow. I'm also going to fish around and make sure nothing is loose or disconnected. If everything checks out I'm going to re-connect the narrowband output from the AFR unit to the ECU and see what happens. I'm still a little troubled that the symptoms and the evidence don't jive. The thing that got me going down this path was more of a lean running/bad O2 relay problem. The only other thing I can think of is that maybe I've got some crud in the fuel tank. I ran a can of BG44k through the tank a few months ago. |
I apologize in advance if I may have created any panic on the Acton dwell meter. My experience was that of one person. The Actron meter I referred to was a model CP7605, a relative cheapy, Sears price about $40. It was described as a meter for measuring dwell on point-type ignition systems, and so I had assumed it would fill the bill for checking Lambda ECUs in accord with Porsche directions.
When I tried to double check it against the actual duty cycle setting of the SunPro meter, as soon as I connected the Actron CP 7605, I watched the scope waveform fall from ~12 volts to roughly half that. I figured that the 7605 was loading the signal from the ECU, so I discontinued the use of it. I just today checked the internal DC resistance of the Acton and found it to be ~ 1MΩ. This seems to be a high enough resistance not to have caused a load indication like I was seeing. So all I can do is pass on is what I saw. The SunPro meter readings jibed with the scope readings and also the relative indications from the DC amperage draw as the duty cycle changed from rich stop to 50% to lean stop. tirwin: From your post where you say - "I started the car and the dwell read 16 on a 4-cyl scale. The DVM read .63 V so it's running rich. I was misreading the Bosch book. With a rich signal, the ECU sends less of a duty cycle. The less time the valve is open, the less fuel injected. To prove this, I grounded the green shielded wire and the dwell dropped to zero. I also heard a slight RPM change so that leads me to believe the ECU is working as it should." Zero volts (O2 sensor grounded) tells the ECU that the O2 sensor is connected, and the mixture is reaaly lean; go to the rich stop at 93% (or so), so the dwell reading (indicated duty cycle) should go high (to max). Remember, the dwell meter reads ignition points dwell. Dwell is the % of time the points are closed. However, this is also the % of time the coil current is flowing. This is equivalent to the ECU set up, and why a dwell meter should theoretically read the duty cycle of the Frequency Valve. The set up is electrically equivalent. Ignition coil = Frequency Valve (both connected to +12 volts) Ign. points = ECU (both connecting each of the above to ground) However the electrical impedance of these two systems is very much different. When ignition points are closed, resistance is LOW. When the ECU "closes the solid state points" that pulse the Frequency Valve, its characteristics are not the same. I don't think all unsophisticated dwell meters, meant for checking ignition points, are up to the task of checking ECU duty cycle. If anyone wants to chime in here or maybe has a different take on this, please speak up. |
Tim, The metal fuel lines are a PITA regarding the wrench. I finally made a frankenstein 3mm tool that I can fit down in the hole and then with a larger allen wrench make the tweaks. http://forums.pelicanparts.com/uploa...1387470757.jpg |
I'm with you on the theory part of how the lambda system functions. I guess what I'm trying to figure out is how that information is displayed on the dwell meter. Maybe it is a perspective problem. My interpretation of duty cycle is the % of time the FV is OPEN. More time open = more fuel delivery. More time closed = less fuel delivery. I would EXPECT that duty cycle would move toward 100% on the gauge with the O2 sensor wire grounded. If I connected a 2V battery to the sensor wire, it should move toward 0%. I clearly saw the EXACT OPPOSITE of that yesterday and reproduced it. Grounding the sensor wire made the duty cycle go to 0%. Given that we now confirm that the mixture is rich, I am wondering if the Actron unit is actually displaying the duty cycle backwards (at lest to our way of thinking about it). If you are correct that the meter is reading the amount of time CLOSED, then the correct way to read the duty cycle on the Actron is actually 1 - (decimal value of % reading). So what I was interpreting as a 20% duty cycle is REALLY an 80% duty cycle ( 1 - .20 = .80). That makes a lot more sense given what I am seeing with my own eyes. The other possibility is the Actron unit is a piece of junk. :D I have a timing light with a digital dwell meter. I am going to hook it up later today and do all the tests again and compare that. Wow. If the Actron unit is actually BACKWARDS of what we expect, then that is a really important tidbit of information!!! :eek: |
A couple things I wonder about...
The voltage produced by the O2 sensor is pretty low. Any chance that all of the additional wiring and the additional control module changes the value seen by the control unit in the car? For instance, if you have .5V out of the sensor, what do you have when the signal finally gets to the car's control unit? Same? Less? Have you verified the proper operation of the throttle microswitch? The 35C temperature switch? Given the temperature in your garage, I'd suggest you have a copy of the '81 Service info booklet handy, so you know what the duty cycle should be. It's complicated. If it were my car, I'd swap in a stock O2 sensor and get a better meter to measure the duty cycle. Good luck, JR |
Looking forward to finding if there is impact from tweaking CO.
javadog,
The voltage produced by a narrowband O2 sensor is only supposed to be 0-1V. So that's completely in the normal range. I haven't checked it at the ECU but that's probably a good idea to add to the list. The O2 sensor was disconnected for a long time and it's currently disconnected now. I'm not ready to throw in the towel on the wideband sensor yet. :) |
I have been talking of 45 degrees as 50% duty. That is on a 4 cyl setting. You are using an 8cyl scale so 50% duty is 22.5 degrees dwell. You are not far away. Slightly rich.
The only time the duty cycle should be at 50% is when the engine is above 15C and the O2 sensor is still cold. JR |
Bob said:
I think I remember that psalt says to set it around 35 duty cycle which is a little rich. The Lambda system will compensate and bring it to stioch in closed loop (dithering) but when you got to WOT you have a bit of extra fuel as the Lambda system is disabled. javadog asks: I thought the duty cycle defaulted to 65% on WOT. Response: The 35 I mentioned is not the duty cycle, I am sorry. It is the dwell degrees on a 4 cylinder setting of a dwell meter - 90 degree scale. This dwell meter reading indicates the car is fighting a slightly rich mixture at idle (which is the intent making the adjustment psalt mentions). The Lambda box is telling the freq valve to reduce fuel. The Lambda system corrects for the rich mixture. If you floor it, Lambda is disabled. and since the 3mm fuel mixture screw is adjusted a bit rich, there is a little extra fuel introduced under WOT at the 65% duty cycle. |
Some basics, as sometimes all this is confusing to think about. The higher the duty cycle, the more time the Frequency Valve is open. The more time it is open, the lower the pressure in the lower chambers of the Fuel Distributor. The lower the pressure, the richer the mixture. Where you say:"I clearly saw the EXACT OPPOSITE of that yesterday and reproduced it. Grounding the sensor wire made the duty cycle go to 0%." But you are believing the dwell meter. I propose that if you are having the same issues with the Actron meter that I had, you can't believe it. If you can't believe it, you don't know what the duty cycle actually is. A dwell meter, by definition, is set up to read ignition points closure, yet it is also reading the time current is flowing in the coil. This would equate to the time current is flowing in the Frequency Valve, as the ECU is duplicating the action of the points. A different type of dwell meter might read ECU duty cycle correctly. The Actron meter may do a decent job with a points/coil ignition. I am suggesting that it does not do a good job with the ECU. I don't believe (although I have no way of knowing this) that the dwell meter the Porsche workshop manual used was an inexpensive two lead meter, but rather a three lead meter, considering the three pin connector the factory installed to connect up a dwell meter. It used +12 volts, ground, and the test lead to pin 17 on the ECU. I think the best way (and maybe the only way) to resolve the uncertainty you are seeing is to beg, buy or borrow a duty cycle meter, or better yet find an oscilloscope to monitor the test connection. If you can look at a waveform trace, you will know what the duty cycle is. |
Jim,
I just got home from a test drive. Progress! I started out with the Actron dwell meter hooked up. I was getting a reading of 6 on an 8-cyl scale, so 12 on a 4-cyl scale. I got out my Innova timing light with a digital dwell meter. I got a totally different reading. 45 on a 4-cyl scale. The O2 sensor is still disconnected so it is running on a fixed 50% duty cycle. That looks more accurate. I then backed off the mixture a hair and went for a drive. Everything was good. The exhaust doesn't smell as bad. So tomorrow I'll hook up the O2 sensor again and see what happens. But I think this confirms your theory that the Actron unit isn't good for this purpose. |
Do you have a reference as to what the '81 Service info booklet is that gives the duty cycles for different conditions? I have my own data that I've measured recently on the workbench, but I'd sure like to see what the factory has to say, as a way to double check the numbers I got. |
This is from 1981, when Porsche introduced the O2 sensor control unit. I don't think they made any changes to it until 1983 when a new unit was introduced. The main difference in 1983 was that the enrichment was kept in place until 25 seconds after the O2 sensor was warm. The enrichment was for 2.5 seconds, which may be a little longer than the enrichment in 1981.
http://forums.pelicanparts.com/uploa...1387554697.jpg http://forums.pelicanparts.com/uploa...1387554716.jpg http://forums.pelicanparts.com/uploa...1387554731.jpg |
Quick update.
Started the car this morning after last night's adjustments. Strong start and very smooth idle. RPMs initially went to 1600. Noticeably less exhaust smell. That is an improvement to me. I used to see more hunting. The hunting seems to only happen in cooler weather -- say below the 60's. Let it idle for a few minutes. RPMs gradually started to drop as expected. When it dropped below 1000 and settled into 900 it started chugging a bit. Best way I can describe it is less like a Porsche and more like a muscle car sound. About a minute later the RPMs dropped down to the 650 range and the chugging got a lot worse so I turned it off. I didn't have any more time to look into it. Last night I did have to slightly increase the idle as I leaned the mixture a bit. I feel like I've almost got it dialed in now. What should I do as the next step? I need to do another cold start and give it more time to get good and warmed up. |
Another update. I had a few minutes at lunch so I thought I'd test the effect of hooking up the O2 sensor. I started the car and let it warm up. Then I adjusted the idle up to 900 RPM.
I rigged up a setup where I could monitor the narrowband output of the sensor with my DVM while it was connected to the ECU. First I started the car with the O2 sensor disconnected. Sensor output was .6V. Next I used the same Posi-lock connector to see if I could measure a difference in output just to rule out that possibility. (Still not connected to the green shielded wire.) I measured a difference of .01V. Then I connected the sensor to the green shielded wire. The car started stumbling badly. RPMs dropped and started surging as the ECU tried to compensate. It almost died a couple of times. The sensor output fluctuated in response to the changing conditions. As soon as I disconnected it, it returned to normal. I think this confirms that the ECU does not like the O2 sensor being connected. We know what signal is being sent by the O2 sensor. What I do NOT yet know is what is being RECEIVED at the ECU as javadog pointed out. Why is the ECU reacting so badly? I wonder if this is the real reason the O2 sensor was disconnected for so many years. |
Maybe the moral of this story should be to ditch the O2 and put in a set of SSIs with M&K 2-in/2-out!!!
| All times are GMT -8. The time now is 07:17 AM. |
