Agfours
agfours's Avatar
Screw size for velvet upper door seal on coupe?
Anyone have a pic or sizing of the tiny screws that hold the velvet upper door seals to the body?
I bought the seals from our host, but don't have a reference for the screws...I understand they are micro tiny, and I don't want to get some that are too large and cause clearance issues with the door frame...
Thanks!
Paul
Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..."
Old 12-19-2013, 08:55 PM
emac's Avatar
I have a 81, no screws just snapped in.
Ernie
Old 12-19-2013, 09:06 PM
Agfours
agfours's Avatar
Thanks Ernie, this one definately needs screws - nothing to snap to, just holes in the body, holes in the seal to be joined by 3M adhesive and screws.
Paul
Old 12-19-2013, 09:12 PM
911Shoes's Avatar
Hope this helps!
Old 12-19-2013, 09:19 PM
Makoshark72's Avatar
I used 6mm stainless steel sheet metal screws (Ace hardware), slightly bigger than the originals, but fit nicely in the original cupped washers...maybe .30 each...Also, several of my original screws wouldn't fully tighten when I reinstalled them, so got the slightly larger 6mm ones...
Rob
2012 Corvette Grand Sport
1972 Corvette Coupe (highly modified)
1979 911SC
Old 12-19-2013, 09:44 PM
emac's Avatar
Agfours--mine had like a bent wire/s in the strip that you lined up with holes in door. Perhaps a trip to a local body shop would help?
Ernie 81sc
Old 12-20-2013, 06:08 AM
