2.7 crank into 3.0 sc case.. which rods?
is ti possible to use a crank from a 2.7 into a 3.0 sc case and which rods would I want to use .... the 2.7 rods and trim down the pin end width? Thnaks in advance for any and all help...
89 Mercedes 300E 77 911s TARGA 79 3.2 widebody 79 911 SC TARGA 97 BMW Z3 |
the only 3.0 case it will work in is an early carrera or turbo 3.0. those engines used a 2.7 crank stock.
If your current 3.0 crank has 6 bolts for the flywheel then you have the right case(lucky you) . If your crank has 9 bolts to hold the flywheel on you have a standard 3.0 type case and your 2.7 crank will not fit.
Kurt Williams
Never drive faster than your gaurdian angel can fly. 82 SC w/965S eng and G50 6:1 hp/w ratio 72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles 65/66 912 1 owner 76k orig 01' Aston Martin DB7 V12 Vantage Coupe 6spd |
aaaahhhhhh yes the HOLY GRAIL of cases.... I guess if I had one of those it would be time to look for a 66mm crank....!
Thanks John and Kurt!
