-   -   Fuchs with spacer or not and does it look right. (http://forums.pelicanparts.com/porsche-911-technical-forum/788163-fuchs-spacer-not-does-look-right.html)
mv70 12-21-2013 09:31 AM
I got this 28mm spacers on rears.
http://img19.imageshack.us/img19/7113/9znx.jpg
I did belive it was because cant fit my Fuchs copies or wrong model for my 911SC -83 narrow.But tried today when had too adjust handbrake and wheels does fit fine.Mabey the are right Fuchs for my 911 :)
But now looking at center hole.
http://imageshack.us/a/img811/8366/wfa4.jpg
shouldn't big hub lips match against wheel lips if it is original type?
Sorry if quest has been upp before but could not find when I did search here.
H-viken 12-21-2013 09:38 AM
Hi
Those should have an ET/offset of 23,3 and would probably fit better up front. They were manufactured between 1977 and 1984. How wide are the Fuchs you have up front?
/Johan
techweenie 12-21-2013 09:44 AM
Hub bore should be a snug fit with the hub. Looks like you need a hub-centric spacer. they are available from many sources. You need to specify inside diameter and outside diameter (i.d. and o.d.) and have them custom made.
What's odd is that the hub appears too small since you're showing part numbers of a stock Fuchs. But it's confusing because you mentioned Fuchs replicas...
mv70 12-21-2013 10:17 AM
I did not know if it was replicas or not. But since there was 28mm spacer I thougt something is not original.
Originally Posted by H-viken (Post 7817663)
Hi
/Johan
I have 6x16 in front. I can see there is front spacers to but not this large as in rears.
http://img694.imageshack.us/img694/3347/t31o.jpg
