Dropping the engine...usggestions on maintenence??
Well I am dropping the engine for a variety of reasons...
but while I am in there I will be doing the follow...please let me know if I missed anything new rotor new dizzy new magnecor wires new fuel filter new spark plugs check for oil leaks check head studs valve adjustment switch to 964 cams get rockers resurfaced new oil filter fixed crushed oil lines clutch adjustment check throttle linkage belts airfilter what else does the dealership and mechanics add in a full maintainence check up... tranny oil and brakes are also being done...but the next couple days will be concentrating on the engine... MJ |
Things to change while in there-
oil pressure switch oil cooler seals thermostat O-ring Intermeadiate shaft O-ring Pulley seal ( check for oil leaks ) check the intake runner hoses if puffy change them. |
Maybe a new flywheel seal, sound pad and rear shocks too.
| All times are GMT -8. The time now is 09:40 PM. |
