-   -   loose connection id on '82 SC (http://forums.pelicanparts.com/porsche-911-technical-forum/788348-loose-connection-id-82-sc.html)
golfbuddy 12-22-2013 11:06 AM
I was replacing the fuel accumulator and noted some kind of disconnected electrical connection just below the fuel filter/accumulator. In the Pelican tech info center (basics part) instruction for replacing the fuel filter/accum, figure 1 shows the male connection side. Anyone know what it is?? :confused: Thanks
Bob Kontak 12-22-2013 11:16 AM
That is the connector the O2 sensor plugs into. O2 wire will come in from the sheet metal on the left side - just look lower. Maybe a one inch hole in the sheet metal if the wire and grommet are missing
golfbuddy 12-22-2013 12:35 PM
Thanks Bob -- Just wondering what it was as the SC was running just fine without it being connected.
Bob Kontak 12-22-2013 01:59 PM
They can run ok without but while cruising your gas mileage may suffer a bit and a richer mixture can impact your cat over time.
