Submerge Caliper
Can a caliper be submerged into brake cleaning fluid without damaging the caliper? What is the best method to clean the caliper? Thanks
That will likely damage the rubber seal on the inside. If you're rebuilding the caliper, then dunk it.
I think if you did this you would have to split the calipers and replace the (4 I believe) o-rings that seals the halves together.
IIRC Eric Shea at PMB said that he only uses soapy water to clean the calipers, then rinse with clear water, and dry with compressed air; no solvents or cleaners. |
Metal castings can have natural porosity
| All times are GMT -8. The time now is 03:02 AM. |
