-   -   Interesting find on my new project car! Questions... (http://forums.pelicanparts.com/porsche-911-technical-forum/789172-interesting-find-my-new-project-car-questions.html)
scottrx7tt 12-28-2013 10:00 AM
I just bought a 79 911 widebody. I already knew it had a 1980 "3.1" block, but the rest was unknown. It had a Holley Pro-jection TBI kit on it with a custom intake manifold. The TBI kit was not operational, so I went ahead and removed it, along with the engine shroud. As I was doing some clean up on the engine I noticed that it has 3.2 heads on it with the date code 2/86!
I was already going to do a 3.2 intake with a Bitz EFI kit on it anyways, which will make things a bit easier, but my question is, how will this effect performance? I know the 3.1 had the 3.3 turbo cylinders with some kind of high compression pistons from the factory. I have verified that the engine still has the larger cylinders.
So, what can I expect?
EPorsche 12-28-2013 11:47 AM
Do you have pics of the engine and engine bay?
scottrx7tt 12-29-2013 03:31 PM
Anyone??
scottrx7tt 12-29-2013 03:33 PM
http://forums.pelicanparts.com/uploa...1388359985.jpg
http://forums.pelicanparts.com/uploa...1388360013.jpg
scottrx7tt 12-29-2013 03:34 PM
http://forums.pelicanparts.com/uploa...1388360065.jpg
RWebb 12-29-2013 05:21 PM
3.2L heads flow real well, bone stock
OTOH, you can expect that a PO who would eff up by using that manifold and carb may have effed up elsewhere too
I assume you will do a full teardown anyway...
scottrx7tt 12-29-2013 05:41 PM
I did a compression test, and all cylinders were 178-180, and no broken studs, so it does not make any sense to tear it down.
Nostril Cheese 12-29-2013 05:50 PM
You need to do a leak down test. I'm sure that the motor was not getting the same amounts of fuel to each cylinder with that manifold setup.
Based on what I see in those pics, yes, tear it down and check everything. That manifold is a serious WTF?
Dan J 12-29-2013 06:40 PM
I would check the cam timing also in addition to checking that it's correct you may
also find the cams have been changed
I agree on not tearing it down if the leakdown/comp is good and it's not leaking oil
MBAtarga 12-29-2013 07:17 PM
What is a "3.1" ? I've never heard of that displacement.
scottrx7tt 12-29-2013 08:06 PM
Excellence :: Point One : The Forgotten 911 SC-L 3.1
rattlsnak 12-29-2013 09:01 PM
I have to say in all my years of P ownership I have never seen or even heard of a TBI setup on a 911! WTH?
911nut 12-30-2013 05:22 AM
Big ports on a 3 L engine will make for sluggish response at low engine speed. This can be overcome with a higher compression ratio. I suggest getting it running as you planned, drive it and decide if you can live with it. The compression ratio might have been bumped already.
tonizzos 12-30-2013 05:32 AM
if it's a real SC 3,1 ... i would not modifie it.... my 2 c
scottrx7tt 12-30-2013 06:11 AM
the porsche 3.1 engine is 9.5:1 with 3122cc's
the porsche 3.2 engine is 9.5:1 with 3164cc's
so there is a 42cc difference, and the compression is the same, so i might be 5hp down from the 3.2, or atleast thats what i think.
scottrx7tt 12-30-2013 06:13 AM
its already been modified with the 3.2 heads, so its definitely not original. Besides, the original CIS is long gone.
