What Front Cooler set up is everyone running instead of the "Trombone"?
Title says it all. It appears as a lot of people are running the factory porsche with the fan set up.... but are there any other alternatives?
Thanks! Paul |
the 28 row cooler and the carrera cooler are popular because they fit but you can fabricate any type cooler you want and it would be 1000% better than that trombone "cooler"
i found this... I'd love to do this one:
Pelican Technical Article: Installing a Mocal 44-Row Oil Cooler in the 911... However; it seems as the cheapest kit is ~$540.00 and *********** is the only one that sells these Mocal kits. Our host only sells the small units from Mocal. Any advice on where else I could look? Thanks, Paul |
Front Cooler
I replaced the trombone in my SC with a Setrab that is a bit larger than the Carrera cooler. I had to build a custom frame to mount it but it seems to work well even in the heat down here in S. Georgia.
some nice choices here...
Elephant Racing | Oil Cooler kits | Porsche 911 |
| All times are GMT -8. The time now is 01:23 PM. |
