Is this new diagram for the book clear?
This is a really tough one to conceptualize. Let me know what you think...
http://forums.pelicanparts.com/uploa...e-engine26.gif Please let me know your feedback... -Wayne |
Looks like the valves move farther than the pistons.
Kind of. Sometimes graphic data presentations cannot be scaled properly. In this case, pistons are actually travelling further than a few tenths of an inch. But if what you are trying to illustrate is the presence of valve-to-piston clearance, and even its cyclical timing pattern, then this graph helps to do that. It's just a little confusing potentially because it is not a graph that can help the viewer understand the actual distances involved. Or does it? Perhaps its scales are trustworthy for both valves and pistons.
O, and it's upside down.;) |
Seems pretty clear to me ... but maybe a scale is needed on the right side for piston travel ... which is approx 6-7 tomes greater than valve lift!
And, it might make more sense for people with spatial orientation difficulties ... to have piston travel on the bottom, and visually at least twice as great as cam lift on the vertical axis ... |
There is a similar graph in BA's book for cam timing.
Makes sense to me (even if it's somewhat out of scale), and helps one understand the concept of valve overlap. |
Try putting a scale on the right for piston travel distance. Might help, but the one posted is fine with me at any rate.
Wayne,
Are you Japanese? You people love to explain technical concepts with graphs. :) It might suffice to say (or add a caption to the chart) that the piston is closest to the valves during the overlap period (end of exhaust, beginning of intake) and piston is at TDC. Sherwood Lee http://members.rennlist.org/911pcars |
Gee, correct me if I'm wrong...but if the synchronization is off? Yeah, valves CAN hit pistons? The illustration looked good to me...BTW, valves hitting pistons? Is that what is called an "interference" engine?
Wayne what you are showing is crystal clear to me.
Perhaps you should dredge up all the technical writting skills for this concept though. All the Porsche engineers could write is thecam timing procedure in the factory manuals..... not the easiest thing to grasp.. Your illustration clearly shows interference between the intake valve and piston......... not a good thing I know your trying to open peoples eyes to the cam/piston relationship in the 911 engine. beside the illustration you should mention the cams rotation in relation to the cranks... then as a big tip to all the first timers........ let them know the dial gauge fluctuates wildly while timing the cams..... and that the reading is absloute.... positive or negative disregarded...... just look at the number when your done rotating the crank |
Good comments, let me work on version 2 here...
-Wayne |
Hey...maybe if we glue flint to the side of the valve....when it hits the piston it will create a spark!!
Far out...I just invented Flint Ignition!! LOLOLOLOLOL Bob |
Bob, I think "we" need to go for a ride! :)
Piston should be on the bottom, valves on the top - that's how most people are used to thinking of it.
Might help to indicate compression stroke, exhaust stroke, etc too. Finally, showing the crank and rod, valve and cam, in the appropriate positions might or might not add something - just a thought. |
-Wayne |
http://www.edwardtufte.com/448274615/tufte/ Highly recommended reading. |
time the cams properly and you can look down the intake.. and rotate the crank and watch the valve follow the piston down. being able to describe the interaction between all these rotating parts is beyond me.....
Wayne I think you should just use points instead of clip art to illustrate the critical points |
Nice! Now I don't have to stand on my head.
Say, Wayne.....it's almost September, the promised date of the B&W preview edition........we're waiting. |
September has 30 days in it...
Odd, because I think of it backwards from how you guys think of it. When you're assembling the engine, the pistons are at the top, and the valves are at the bottom. If you stand next to the engine, and look down at it, the pistons are located above the valves... -Wayne |
Just wondering; if you flip the chart 180º, the components would be in their "normal" orientation - valves on top, piston on bottom. Most 4-stroke cycle charts are oriented in this way.
Sherwood |
I guess my observation was about an hour late; somebody else got there earlier.
I wrote: "It might suffice to say (or add a caption to the chart) that the piston is closest to the valves during the overlap period (end of exhaust, beginning of intake) and piston is at TDC." and Wayne responded: " ..... that's not correct! As the graph shows, at TDC, the valves may not be closest to the pistons. It's on the upward stroke that they are closest (of course, it depends upon the camshaft). That's the point I'm trying to make here - that the TDC point is *NOT* where you have to worry about interference! " Wayne, I'm trying to understand what you're saying. If the piston is indeed on it's upward stroke (not near TDC), then there is no way BOTH valves will be closest to the piston. The only time BOTH valves are open is during the overlap period as the ex. valve is closing and the intake valve is beginning to open. If you're referring to one valve. becoming closer, i.e. the exhaust valve, yes, as the chart points out, the exh. valve-to-piston clearance narrows, but is especially critical as the piston approaches TDC. Likewise, during the intake stroke, the in. valve begins to open while the piston is moving up the cylinder. The further away from TDC, the greater the valve-to-piston clearance you will have, and conversely the valve-to-piston clearance decreases the closer the piston is to TDC. With difference camshaft profiles this could be different, but in general terms that's what happens. A cutaway of a Porsche cylinder going through a 4-stroke cycle would tell us exactly what's going on but I suspect it's like most other 4-stroke cycle engines. We might be splitting hairs with the number of crank degrees vs actual piston location in the cylinder. The crank rotates quite a bit while the piston is around TDC. Sherwood |
Some comments (its early in the AM so forgive me if these are a little incoherent)
The comments on scale (to show that the piston travelled farther than the valves) made sense to me when I read it but now on version 2 there is too much dead space at the bottom of the graph The clearance graphic doesn't make that much sense to me. It isn't clear from the graph why you have put it where you have. Maybe you could add a third line to show piston to valve clearance as it varies with the degrees of rotation You could also add small diagrams showing the piston and valve in a cylinder at critical points - this may be overkill for your target audience though And my two cents worth about the valves on top or bottom discussion - they should be on the side. Isn't the book about Porsches - horizontal engines - LOL |
Second version is much better but, the degree markings could be confusing to those less knowledgeable. The current diagram has crankshaft degrees at both the bottom and top, I think it would be better to place camshaft degrees along the top near the valves to give folks a better understanding of cam timing. This would also help folks understand how retarding or advancing a cam could cause piston to valve clearance issues. As an aside this graph could also be used to describe how valve float from an over rev condition can cause the valves to hit the pistons.
I think you're d**m lucky to get any graph at all sonny. In my day...
-Chris |
The suggestions about camshaft degrees at the top is a good one. Also good may be a third line showing piston to valve clearance.
Sherwood, the point where the piston is closest to one of the valves is not at TDC. It's actually before TDC, because the valve is still open quite a bit. Contrary to popular belief, when you over-rev and your valves hit the pistons, it's not happening at TDC. At TDC, there is quite a bit of clearance, as the valves are almost completely closed. It's when the piston is coming up towards the valves, and they are still open where the clearance problem is. I have a whole section in the book dedicated to checking this... -Wayne |
This suggestion will overlap some of the others made, but perhaps having 2 of the clearance arrows: 1) clearance is smallest here 2) clearance is greatest here, or 2) This is clearance at TDC, etc . . .
Look forward to buying the book. Michel Richard |
if you want show over rev, when the valves float, do something like. . .
http://forums.pelicanparts.com/uploa...ine27float.jpg . . .of course this is *if* the valves go thru the pistons ;) |
Good idea, Island.
Wayne, I'd include all four strokes of the engine. |
1 Attachment(s)
Wayne,
How about something like this? |
That's not bad Gary, but it portrays the wrong message. The distance at TDC is *not* what you need to worry about...
Hmm, let me think about this some more... It's not an easy thing to convey... -Wayne |
I really like Garys choice of colors for the valve paths, and the addition of closed valves at the end points. . . .I don't think he was too focused on the accuracy of the sinewaves.
1 Attachment(s)
OK then, to de-emphasize TDC clearance which is not the issue, would you want to empahsize max intake lift clearance or some generic timing as shown here?
Small point - you may want to caption it MINIMUM valve clearance
| All times are GMT -8. The time now is 10:57 PM. |
