Terrifying Porsche Moment
At 6:00am this morning I was heading down an empty four lane interstate at 80mph making my way to an early meeting. Car was good, music was good, all seemed well. Snapped the following photos:
Perhaps I should leave the picture taking for later...
I exited the freeway and got up to about 20 mph on a perpendicular (and again empty) street when my front hood flew open. It took just a nanosecond to stomp on the brakes, and due to the cold ambient temperature and the shot hood struts, the hood immediately closed. I pulled over and exited the car, very well shaken.
When I opened the trunk/hood, I noticed the latch was still latched. Two 10mm nuts were lying next to it. I went back to the front seat and pulled the cable and the latch released. Because the primary AND secondary latches are part of the same assembly, and because it came off in its entirety, my hood flew open. A minute earlier I was doing 80!
The car was restored by a P Car specialist a few years ago. I have no way of knowing if they tightened it or not. I only found one lock washer, but the other could have fallen out. I never thought to check this, nor is it on my list of pm items. Thought others should consider it.
The hood looks okay with no visible buckling etc. I reassembled the latch/hood on the spot as I had to get down the road a bit, and it seemed to tighten up just fine. Now, however, when I pull the release it only opens a bit. I have no idea why, nor do I know how to release it. The cowl below the windshield has two of these:
Not sure of my next step. I now have a dented cowl, a hood that won't release and a fear of what's next!
1972 911T/S MFI Survivor
Old 12-27-2013, 12:25 PM
Now that's a new one. I'm going to check the latch on the 70 before the next ride.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 12-27-2013, 12:30 PM
1988 Carrera
shadowjack1's Avatar
Reading this in the garage, opened hood, removed nuts, applied loctite and installed new lock washers. I feel better.
Old 12-27-2013, 01:14 PM
Functionista
manbridge 74's Avatar
I've had this happen on a customer car (MGA) and it will flat ruin your day. Especially so when the job was in the rear end area and we never popped the hood! Just drove it around the block to park it. Thankfully it happened at low enough speed that no damage was evident after we were able to massage the slightly bowed hood back into shape using blankets over the engine.
Once a year I go ever every bolt and nut I can reach on the entire car. Just a snug up, no gorilla tighten.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 12-27-2013, 01:20 PM
Go-Kart Mozart
JAR0023's Avatar
When you pull the release the hood should only open a bit. That's the secondary safety catch working. I'm assuming you mean the main latch is not releasing cleanly? Can you pull the hood up enough with your hands to work the safety catch? I'm going to go with the hood striker is not perfectly aligned with the latch and it's hanging. You have left/right and some front/back adjustment with the striker and up/down with the latch. Once you get it open, watch closely as you close it and check for alignment of the striker into the main latch. Adjust as needed. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 12-27-2013, 01:25 PM
Straight shooter
Lapkritis's Avatar
Ouch. Out of pocket repair probably cheaper in the long run than claiming it. Might be worthwhile to contact the restoration house to see if they might work a deal for you considering their recent involvement and just rotten luck.
Edit: and let that thing warm up a bit!
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 12-27-2013, 02:24 PM
Unfortunately I spent no time doing any aligning in the dark. It's obvious now I should have. The hood does pop up some when I pull the cable, but not as much as it used to. I think I'll play around with some slim steel and see what I can do. It does not, however, pop up as high as it used to - I cannot get my fingers in to release the secondary latch - it is only popping up 1/4 to 3/8 of an inch.
Old 12-27-2013, 03:38 PM
ahead of the curve
Jeff Burger's Avatar
get someone to pull and hold the release while you twist and push and pull up on the front corners of the hood - that usually will get the male part lose then you can get to the safety catch and release normally. If you have no one to help you can use a pair of vise grips to hold the release in the pulled position
Don't go crazy on the hood - also make sure the vise grips are on the metal shaft not the plastic
good luck
19 Carrera T - MPS member
92 C2 SR coupe M491/ 3.8 look- manual
92 C2 SR coupe cobolt blue- manual
73 914 1.7 (?) AG -a solid project looking 4 a sugar daddy
73.5 T gemini blue SR coupe sold 8/22 my last long hood gone
Old 12-27-2013, 03:52 PM
theclaw's Avatar
Happened to my while driving my '72 Datsun pickup back in the '80s. Only I was on the highway and the hood didn't flop down. I was in the Air Force at the time and just considered it another inflight emergency. Except I wasn't flying, only doing about 65mph.
'84 Carrera (recently sold )
'67 MB 250SL
A few Italian motorcycles
......and a minivan for the crew
Old 12-27-2013, 03:55 PM
Happened to me with my 70 Bronco at night in sleeting rain, running about 70. Scared the hell out of me! Put a crease in the hood. An Oregon State Trooper helped me tie it down so I could continue my trip.
75 911S Widebody, 88 M6, 86 944 Turbo, 90 300ZX TT,
94 325ic, 73 3.0CS, 73 240Z, 74 260Z, 69 AMX, 97 SS Z-28,70 Bronco, 2000 ZR-2 Blazer, 2002 2500 Avalanche 8.1 ltr 4x4, 1984 928 S 5-sp, 94 K1100 LT Few more. Caution this person extremely addicted!!!!!
Old 12-27-2013, 06:16 PM
irl irl is offline
irl's Avatar
Send a message via AIM to irl
Wow, glad your OK. Shocked there wasn't more damage.
Old 12-27-2013, 08:41 PM
Well, I got it open over the weekend. I just had to push it towards the rear as my son pulled on the cable. I have adjusted it back to where the prior marking indicate it was set. I will now be buying some Locktite.
Incidentally, someone has removed it before, as it did not have any lock washers on it. It does now!
So now I have to find some one or some way to remove the two dimples from the cowl. Anyone know if there is a way to access the underside of the cowl?
Old 12-30-2013, 09:45 AM
irl irl is offline
irl's Avatar
Entire cowl is accessible, just have to remove things. Here is a shot with a piece cut out.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 12-30-2013, 09:52 AM
bgyglfr's Avatar
That is a scary situation. I had a mgb gt for sale years ago and a guy came by to look at it the day before he test drove it (before i had a garage). He opened the hood and never latched it all the way closed. He proceeds to drive it the next day and destroys the hood. He had the nerve to try to beat me down because of the damage he caused. Freaking A$$ H. Still makes me angry when I think about it.
70T 2.7RS spec.
68L coupe
Old 12-30-2013, 10:01 AM
Monza_dh's Avatar
I have the same issue with my cowl and have had a few dent guys say if they attempt to push out the dent the paint will crack and it will need painting. see my thread below.
Dent/Bodywork advise needed.
$35 and a six pack to my name.....
'88 Diamond Blue Carrera CE 3.4-SOLD
Old 12-30-2013, 10:50 AM
michael lang's Avatar
I'm sorry that happened to you, how did you know to take the picture before that happened? Or was it just dumb luck?
Mike
'89 CARRERA
#402
Old 12-31-2013, 11:44 PM
Rescuer of old cars
Arne2's Avatar
Ahh! I've often wondered what caused that exact cowl dent on the passenger side of my car, now I know. A close inspection shows a matching paint chip on the driver's side, as well as chips on both points of the lid corners.
FWIW, my car does have lock washers on both nuts holding the latch plate to the hood. Both are/were tight when checked today.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-01-2014, 09:02 AM
I just take a lot of photos. That morning I was just excited by the promise of the new day and the sun rising over San Gregornio and snapped a few fotos. Thirty seconds later the hood popped open - after I exited the freeway!
Old 01-01-2014, 09:10 AM
Monza - it cracked my paint so I have no option but to paint.
Old 01-01-2014, 09:12 AM
