My Steering Wheel shakes at speeds over 120 mph
My Steering Wheel shakes at speeds over 120 mph.
Is this normal?
Thanks for your input!
Old 12-25-2013, 02:11 PM
BlueWing's Avatar
Just stay at 119 MPH
79 SC Minerva Blue ROW
Non Sunroof Crank Window Coupe
3.0 SSIs, Backdated Heat
COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires
Old 12-25-2013, 02:27 PM
ZAMIRZ's Avatar
No, it's not normal.
Amir
'83 911SC
Old 12-25-2013, 02:36 PM
emac's Avatar
Not right
Old 12-25-2013, 03:00 PM
Maybe your driving skills make it nervous.
Sorry. It's been a very long, quiet day.
"Life is good"
Old 12-25-2013, 03:35 PM
French Import
zippy_gg's Avatar
What happens if you go over 120mph, say 130-135mph? If the shaking stops you may just have a slightly imbalanced wheel.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 12-25-2013, 03:45 PM
Buy a new steering wheel.
Old 12-25-2013, 03:48 PM
RETIRED
Joe Bob's Avatar
How old are the tires, what is the pressures? Have you checked for lost wheel weights, loose tie rods, road hits on your wheels?
2012 ML350 3.0 Turbo Diesel
Old 12-25-2013, 04:23 PM
Crusty Conservative
silverc4s's Avatar
Depending on front / rear spoilers on ÿour SC, the front end is probably getting pretty light due to the air piling up underneath. This will tend to magnify any front end deficiencies you may have.
This can also be a very easy way to lose control of your car, so please play with cautions in this speed range in a street car.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 12-25-2013, 07:00 PM
Tsunamiboy's Avatar
Most often it's tires at those speeds.
Tsunamiboy
1979 911 SC (3.2L)
1997 Boxster 986
Old 12-25-2013, 07:35 PM
kramer747's Avatar
lol-who's 911 goes over 120?!
Old 12-25-2013, 08:50 PM
Thanks for the replies...
I have 17" wheels and tires which are fairly new. I have
a low front spoiler as well.
I'm thinking possibly new bearings... or maybe a strut brace would help. The tire
pressure is 30psi front and rear.
Could it be a problem with the bushings or maybe tie-rod related.
Should my car 911 (930) 3.3L drive smoother at high speeds?
I'm thinking 150 mph should be smooth as 120 mph which should be
as smooth as 100 mph.
As for driving fast. Is there really a difference in driving 120 mph verses 85 mph other then tire speed rating?
Again, thanks for the replies!
Old 12-25-2013, 09:34 PM
Sounds like a simple wheel balance is in order
Old 12-25-2013, 09:45 PM
I'm going to start, as suggested, and check for lost wheel weights and balance. I’ll most likely just have the wheels re-balanced and at the same time check for loose tie rods. Thanks all for replying... Oh yah... and Merry Chrismas!!!
Old 12-25-2013, 09:49 PM
I agree. Safety first! Driving at high speeds can be very dangerous.
I was just wondering for those who have driven a 911 (930) over 120 MPH what it felt like.
Shaky or not?
Old 12-26-2013, 01:42 AM
No, not at all. Vibration is not normal.
JR
Old 12-26-2013, 01:46 AM
If all is well it should be smooth as silk all the way to 150 mph!
These cars track very well at all speeds if all is in spec!
Sounds like tyre balancing or a bent wheel, tie rod or ball joint to me.
Did you change the tyres or anything else rightl before this j happened?
Cheers
Bill
1977 Carrera 3.0
This much fun must be illegal!
Old 12-26-2013, 04:09 AM
cary's Avatar
Cheers
Bill
Ditto .............
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 12-26-2013, 06:45 AM
I've spent a fair amount of time in 911s over 120. Went 170 on the Autobahn as a passenger in a 964 Turbo, and spent enough time behing the wheel of my own cars (my old 79 930 and my current 72S). You should be getting feedback through the wheel but vibration, heck no. It sounds like you're on the right track with trouble shooting it so I'll go ahead and throw in some more jokes.
Have you tried switching wheels? take the culpret wheel with you. If it still shakes at 120 than I would say it's posessed and a preist is your best bet.
83 Chrysler LeBaron
86 AMC Eagle
90 Geo Storm
Old 12-26-2013, 07:08 AM
The 17" wheels on the car are aftermarket. I am going to change the wheels back to 16" fuchs wheels I have and have them balanced. I will have the 17's balance checked to see if they are off balance just to know if that might have been the problem.
Also, I am going to replace the tie-rods and ball joints.
Any thoughts about changing the bearings or anything else that might make the car safer at high speeds?
Thanks all...
Old 12-27-2013, 12:39 AM
