goldgunner's Avatar
Sunroof - Rear Rubber Seal
Some help please
The photo immediately below from the tech article: Yellow Arrow
My new rubber seal, when centered, is about 1.12" short from each sunroof edge - not like the pic showing within about 3/16".
My new rubber seal seems to be quite a bit narrower than the yellow arrow item.
Thoughts about the 2 differences above?
Also: location of this rubber seal. This photo and all the previous threads and PET don't make it clear.
Is the rubber seal up against the ledge where the felt seal sits?
Out from that edge? How far?
Finally, someone else asked this question and the picture is from their unanswered thread: orientation of the rubber seal? See 2nd picture below.
PET seems to show the seal 'opening slot' facing forwards (Front of Car/Sunroof) - correct or not?
On the other hand, the Yellow arrow photo above doesn't seem to show the short side edge of the seal that would be visible if the 'opening slot' faced forward and the larger flat side was glued 'down'. Something is amiss or amuck here...
Help please - that's about 4 different questions/issues on one dufus seal...
thanks,
Jim
1980 911SC - 2nd Rebuild in Process - 2005 Porsche Cayenne Turbo - 2013 VW R
________________________
2000 BMW X5 - 1996 BMW 530i - Toy 4 Runner (x2 or 3) - 1987 Toy Supra - 1988 Honda Si - 1984 El Camino Super Sport - MGA - MGB - Fiat 124 Spyder - Fiat 128 Wagon - 1962 Karmann Ghia - 1951 VW - 1953 Willys Jeepster w/Chevy 286 - 1995 Volvo 960 - 2006 VW GTI
Old 03-04-2006, 12:25 PM
goldgunner's Avatar
A Sunday bump...
Old 03-05-2006, 05:20 AM
goldgunner's Avatar
a hopeful Monday bump...
Old 03-06-2006, 01:36 PM
goldgunner's Avatar
ok...last chance for elucidation
Old 03-09-2006, 05:50 AM
Designer King
Paulporsche's Avatar
Sorry to see noone has helped you. AFAIK the slightly shorter length and narrowness of your new seal are not problematic. On my car, I don't even think I had an open or closed face (slot). I think I just had a solid piece of rubber, which was up against the felt seal. It seems that the opening or slot should face rearward so it doesn't collect water.
That's the best I can do. At least this will bump it for you and maybe someone more knowledgeable can jump in.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 03-09-2006, 09:11 AM
Wildman Emeritus
I asked the same ? once & never got a resolve. Believe that I faced the slot toward the rear. No problems, but I don't drive in the rain.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 03-09-2006, 10:05 AM
I just did the seals on my '82 SC and noted the shorter rubber piece. Don't think it matters. Looks like it's intended purpose is merely to funnel water to the sides of the sunroof well where it will drain away, (make sure your drains are clear). If water does get by the main seals, the rubber strip catches it and directs it to the side. As long as the rubber is long enough to overlap the well sides, you're golden. I mounted mine with the groove facing forward, narrowest face down. Works great. I also left a gap between the felt seal and the rubber one so the water had space to move to the sides.
Old 03-11-2006, 12:07 PM
goldgunner's Avatar
Thanks Bryan~! Sounds like you thought it out and applied reasonable logic - and often that's about all we get to do with some of these details...
I'll use your methodology on this - seems more likely than not!
Your 1st post Bryan? Keep it up!
Regards,
Jim
Old 03-11-2006, 12:50 PM
Yep, first ever. Been buying small bits from these guys for awhile and have always liked them. Was looking through the forums for exhaust info when I saw your post and figured I'd give it a go.
Old 03-11-2006, 01:42 PM
diy83sc's Avatar
Just did my seal and agree that it is shorter side to side and approximately what you quoted. Similar to the other pictures, mine measured about 4mm parallel to the roof top.
Hope this helps others as well.
Old 01-05-2014, 07:29 PM
