Name that oil leak
I'm tearing this engine down to look for the source of a leak. This picture is of the top of the engine, looking from the rear of the car toward the front of the car. Where do you think this oil is coming from? The flywheel seal looked bad (lots of oil back there). Possible that the movement of air forced the oil up over the engine?
My guess is the t-stat o-ring or pressure switch.
I am whith JR + upper oïl cooler seal comming from top engine .
Thats an early engine, before 74, nothing has to be tight to run so you have bleeding from the thermostat o ring, the cloth wrapped hose to center case, and drainage from the air filter because its sucking fumes off the oil tank.
That isnt fresh oil, its years of bleeding. Bruce |
Thanks. So I'll change the thermo o ring and pressure switch, clean it up, and hope for the best.
French Import
Name that oil leak
Name that oil leak: Exxon-Valdez
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
83 911 Production Cab #10
I'm with Gilles, its a big one
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
The guy who sold it to me said it had a "bit of a leak." Understatement of the year.
French Import
RETIRED
Do the others as well....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
muck-raker
check that crankcase breather hose too. If it's all dried up and cracked, replacing all those gaskets will do you little good.
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Since its out I would re-seal everything I possibly could, and hopefully you get it. But it could be the case.
james www.gruppe9autowerks.com Its not how fast you go...its how you go fast |
Banned
George. That oil leak is named George.
You're welcome. |
Cast iron T engine. Breather plate gasket,thermostat oring & new breather hose,just like everyone else says.Looks pretty normal for a early engine.
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
