-   -   Help: Specific 964 Cam questions (http://forums.pelicanparts.com/porsche-911-technical-forum/790391-help-specific-964-cam-questions.html)
endoquest 01-05-2014 08:56 AM
Hi all, long time reader(nine years), very rare poster. I usually search and find what I need.
I have an '84 Carrera 3.2 with SSI and Steve Wong chip. The car has 105K miles on it and is driven in a spirited fashion on road and track, the motor is in excellent condition and runs very well. I'm dropping my 915 tranny for a rebuild and have decided to install a 964 Camshaft while the motor is out. I've done some research on the cam but can't find or have missed some other information:
1. Do I need to change/reprogram the DME chip? I have an early '84 and had to send the whole box to Steve.
2. Is this really a straight swap or is there ANYTHING else that needs to be done regarding the camshaft?
I am mindful of all the things that need to be done while the motor is out, and they will be done.
Thank you!
Geronimo '74 01-05-2014 09:23 AM
1. Best to have the chip reprogrammed
2. One of the 964 cams needs to be machined to fit. Easy job though, no biggie.
More info here: http://forums.pelicanparts.com/porsche-911-technical-forum/658862-cost-remove-power-steering-drive-964-cams.html
endoquest 01-05-2014 09:46 AM
Thanks Geronimo, didn't know about the PS grind, I'm sure I can do it "in house".
I'll call Performance Chips tomorrow. Does anyone have anything else about the chip? What are the parameters/reasons for the reprogramming?
