-   -   Ball Joint Wrench Socket (http://forums.pelicanparts.com/porsche-911-technical-forum/790501-ball-joint-wrench-socket.html)
Autoban 01-06-2014 05:30 AM
I received the socket (PEL-TOL-P210) for the ball joint to A-Arm Nut. Anyone knows why it is "FOR INSTALLATION ONLY"? It looks to me as the perfect tool to also take the nut off.
Juergen
pete3799 01-06-2014 05:42 AM
Torque on the new nut is 184 foot pounds.
Torque needed to remove the old nut......usually astronomical.
Chances of rounding off the tits on the new socket during removal a quite high.
wildcat077 01-06-2014 05:59 AM
You can use a big ass pipe wrench with a three foot fence post extension to remove the ball joint nuts,the socket is for reinstallation purposes !
Cheers
Phil
john walker's workshop 01-06-2014 06:42 AM
been using mine for years to get the nut off. ignorance is bliss.
Autoban 01-06-2014 06:54 AM
Thanks for all the replies. I guess I will give it a try on Saturday using the tool. So far my car has not given me much trouble taking parts off (shocks, engine and transmission mounts, O2 sensor, etc.). I hope this will also be the case. If I can't get the nut off with a "reasonable" amount of force I may just use a Dremmel Tool and cut it off. I did order new nuts anyway.
Juergen
Jdub 01-06-2014 07:08 AM
I have heard folks use cold chisels and Dremel cutoff wheels to remove the old item, carefully, so as to leave all threading in good nick. Like the pin, these are use-once items that you discard for new (IMHO).
Autoban 01-13-2014 05:08 AM
Replaced the Ball Joints last Saturday. I ended up using my Dremel to cut the old nut as much as possible and then a chisel and a big hammer to get it off. Worked pretty well. Still need to finish some other maintenance items and then I can drive the car again.
Juergen
74-911 01-13-2014 09:30 AM
Originally Posted by Autoban (Post 7853790)
I ended up using my Dremel to cut the old nut as much as possible and then a chisel and a big hammer to get it off. Worked pretty well. Juergen
The above is the method I also used to remove the old ball joints....
As to installing the new ball joints, my procedure was a bit different from most:
After looking at the cost of the special socket plus the fact that I do not have a torque wrench that will go that high, I took the newly powder coated control arms to a local Porsche independent shop and for essentially the cost of the socket he installed both ball joints.
I didn't have to buy a fairly expensive socket that I would use one time nor try to borrow a big enough torque wrench. YMMV but this worked really well for me.
scarceller 01-13-2014 12:35 PM
I used this tool by KD Tool and it worked OK for installation:
KD Tools 4 Lug 4WD Spindle Nut Socket 1 2 Ton GM Dana 50 3937 | eBay
Fraction of the cost.
Racekar 01-13-2014 04:11 PM
I have the KD tool from previous projects, and could not get the nut loose even with heat and soaking for a few days. Chisel and a BFH removed it in 2 min. I consider it a replacement part anyway.
