-   -   do I go all out and upgrade the trailing arm bushing too? (http://forums.pelicanparts.com/porsche-911-technical-forum/791453-do-i-go-all-out-upgrade-trailing-arm-bushing-too.html)
mattn 01-12-2014 03:11 PM
Upgrading the suspension - front is almost done: ER polybronze a arm bushings, monoball strut tops, along with rebuilt calipers, new rotors, new master cylinder, stainless lines, etc. Moving to the back, will do all the same brake renewal along with polybronze spring plate bushings.
With all that, do I go one step further and upgrade the trailing arm bushing too? Car is a 1972 911T so will have to assume the original bushings. I'm almost inclined to just do it since I am doing so much else, but wasn't sure if there would be noticeable improvement.
If I do, having never been that deep into the rear suspension, any more difficult than, say, the front...? Which I also did for the first time...
James Brown 01-12-2014 03:23 PM
might as well as long as your this far, hate to find out later that they did need changing
mattn 01-12-2014 03:26 PM
I think I probably knew the answer all along... :-) Do you think that bushing makes a difference? The others are more intuitive to me as having a noticeable effect...
James Brown 01-12-2014 03:54 PM
makes a big difference, holding the trailing arms in correct alignment. like putting just the front rear polybronze bushings in and leaving the old front rubber ones alone. But you knew that!!
mreid 01-12-2014 04:53 PM
If you have the spring plate unbolted, you might as well. Another 15 minutes and the arm is out and about an hour to change the bushing (banging out the shell halves is a real pain). It makes a big difference!
tobluforu 01-12-2014 05:56 PM
For the rear on your car you will have to drop the motor 5 inches or so.
Charles Freeborn 01-12-2014 07:34 PM
In a word "yes"
~C
McLaren-TAG 01-13-2014 05:57 AM
What are the symptoms of worn out trailing arm bushings?
tharbert 01-13-2014 06:11 AM
Change 'em. If you don't, you'll always wonder why you didn't. You are talking about a small effort with low expense that won't appreciably steepen the slippery slope.
