3.2 DME rework - upgrade to 28pin socket
I just wanted to share a couple of iPhone shots showing the correct way to rework the DME PCB. This unit needed a 28pin socket upgrade amongst other things. While some simply add the four missing pins and call it a day I don't like that approach. To do this correctly I de-solder and remove the old socket and clean up real good:
http://forums.pelicanparts.com/uploa...1389593278.jpg Then I install a new high-quality 28-pin socket and solder it in place properly. The key to good soldering is cleanliness, the right solder and good temperature. Top row done: http://forums.pelicanparts.com/uploa...1389594154.jpg and the finished product: http://forums.pelicanparts.com/uploa...1389593309.jpg Ingo |
that is very nice work, very clean.
I wish I had a de-soldering station. Somehow I never could bring myself to justify one or a hot-air rework station either. This was all done the good old-fashioned way with a soldering iron.
The hot-air station might make sense at some point when it comes to the SMD D-PAK devices with large cooling areas soldered to the PCB. Ingo |
Nice job Ingo! Considering it's my DME i'm very pleased... :D
Dme 28 pin
NICE JOB....but why converting it in the first place? any advantage?
Nice work Ingo. I have forgotten how handy you are with these things...I'll keep in mind for future work :)
Nice work, indeed. Good temp,..and clean!
BEST! Doyle |
- It probably has the most sophisticated part throttle maps and software - that makes for better drivability - When you plan to get a custom chip for the DME the tuner most likely wants to work off the later code base - The only EPROMs you can purchase today is the 28pin 27C512. If you buy a smaller 24pin EPROM its either NOS (new old stock) or used. This DME will get a custom-tuned chip later. Depending on what the tuner works on I would always want to start with the latest base maps. Some only work on the WOT maps from what I understand. Regards, Ingo |
Nice wetting Ingo.
| All times are GMT -8. The time now is 01:04 PM. |
