-   -   Question About CIS pressure tester (http://forums.pelicanparts.com/porsche-911-technical-forum/791610-question-about-cis-pressure-tester.html)
wacko 01-13-2014 02:13 PM
Hello,
Do you need the extra fittings that usually come with the CIS pressure tester? I have found a used one that has been used on a 911/930 but it doesn't have the extra fittings.
Thanks in advance.
tirwin 01-13-2014 02:29 PM
I think that is a qualified "it depends" answer. If you need additional fittings I think you can find them, especially if the used one is the right price.
MotoSook 01-13-2014 02:45 PM
Originally Posted by wacko (Post 7854623)
Hello,
Thanks in advance.
If the fittings on the gauge/tester work for your car now, you won't need any others. You won't be changing fittings.
T77911S 01-14-2014 05:31 AM
i have a brand new CIS tester i was going to sell but it did not come with the gender bender (male to male) fitting. i had an old WUR that i pulled the fitting off of for mine.
i will do 75 for the tester plus shipping.
its this one.
Tool Aid 33865 C.I.S. K-Jetronic Fuel Injection Tester with Case - Amazon.com
