Front Sway Bar Diameter
what is the stock front sway bar diameter for a 1985 Targa? I tried the search bar but came up empty. Thanks. Joe
Sway bars.........
Joe,
These are the diameters (mm) of sway bars for the following cars: SC..........................20.3 mm/18.0 mm (front/rear) from '78 - '83 Carrera 3.2............21.0 mm/20.3 mm (front/rear) from '84 - '86 Carrera 3.2............22.0 mm (front) from '86 - '89 Carrera 3.2............21.0 mm (rear) from '87 - '89 (G-50 cars). Tony |
Thanks Tony, just what I needed. Joe
I think that is incorrect.
'78-'85 should be 20mm front, 18mm rear. In '86 they switched to 22mm front, 21mm rear. The 21mm rear bar from '86 was unique to that year - the '87-'89 rear bar had a dip in it to clear the G50, but they remained 21mm in diameter. |
| All times are GMT -8. The time now is 08:49 PM. |
