Friend of Warren
Fan Housing Cracked, Anyone Have a Used One?
What I thought was an alternator with bad bearings, turns out to be a fan housing full of cracks that the dreaded previous owner tried to fix with several tubes of epoxy. So, does anyone know where I might find a used 3.2 fan housing? (A new one is $476.00!!) And while I am waiting for one, what is the worst that can happen if I keep driving the car with the old housing? I loosened up the fan strap bolt to take some pressure off the cracked housing. I also loosened up the fan belt, but not to the point it is slipping. Thanks for any and all advice.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Kurt,
If you can clean off the epoxy with aircraft paint stripper, use a Dremel cutter to widen the cracks to a 'V' shape ... then I believe the housing can be MIG-welded and be usable again. The welder should be told it is Magnesium.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Senior Member
Kurt,
I had the same problem and mine was welded by a local shop with no problem. The welder mentioned that it was a mix of metal but had no problems and it has lasted for over 3 years and cost $20 or so to fix. It was turned around and fixed (with an alternator overhaul) in half a day... Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Friend of Warren
I have a mig welder and am not half bad with it. What wire would you use to weld the housing? Steel? Aluminum? Do they even make a magnesium alloy welding wire?
Senior Member
Kurt,
Not a clue on the rod, and I have done my fair share of welding as well. When mine was done they said that it was a mix of metal and not just pure magnesium but not sure. On a "interesting" metal like this I would at a minimum take it to a welding shop and ask them, and for the $20 I was charged in my case it was well worth it, especially should I have tried it and made a mess of it! Joe
Home of the Whopper
The dreaded PO did not touch the alternator or fan housing on your 86 Carrera. Maybe the PPO did. And if you want to discuss epoxy, do you have stock in JBWeld? I am still scraping it off all imaginable places on the 72!
