horn and 930s steering wheel install
Hi....
This evening I installed Mitch's steering wheel bushing, and eTarga's LED lights, and the hub and 930 steering wheel that my beloved wife gave me for Christmas. Everything seems to have gone together without too many issues but I am having problems with the horn. My 84 original steering wheel had one wire and one connection for the horn. The new hub has two wires each with a slightly different sized connector that fit only on one of the two tabs on the new wheel. Whenever I reattach the battery, continuous horn. I loosened things up a bit with the same result. What am I overlooking or doing wrong? Thanks for your help everyone..... Tim |
You are completing the ground circuit. maybe the wire is pinched when the wheel went on, mine did the same thing and that is what I found. It was a long time ago so I cannot remember exactly but that is what is making the horn sound continuously.
