cruise control removal
Hi, I removed the cruise control; two hoses and electrical connections still in car. What is recommend as far as the two hoses are concerned, and should I just roll up the electrical and tie them off with zip ties. Anyones imput is appreciated and thanked in advance.
Regards, Clinton
"The greatness of a nation and its moral progress, can be judged by the way its animals are treated." M. Gandhi 1977 911S...sold; 03 F20C; 2009 VW Jetta Sportwagen |
bump 8)
The larger hose is just a vent. It should just lift off with the unit. The smaller of the two hoses is a vacuum line that needs to be blocked off.
Tim |
Senior Member
Plug the vacuum line with a golf tee and tie every loose thing up so it does not get in the way.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Thank you for your responses.
Regards, Clinton
