LinkBack Thread Tools Rating: Thread Rating: 2 votes, 4.00 average.
Slumlord
Porsche_monkey's Avatar
Dash Repair 101
My cab is waiting for the painter, so, time to attack the crappy dash that got sunburned while it lived in California. (Think Phyllis Diller pre-face-lift).
Anyhow, once I removed it, I dropped it off at the local 'interior repair guy'. His estimate was not 'amenable to my current financial situation'. Basically he wanted over 120 gallons of 100 Octane gas for the repair.
So, plan B, patch sand and paint.
Starting with:
Hey, I said it was bad...
I patched the holes with two part epoxy bumper repair caulking...
Next some coarse sanding followed by water sanding the entire dash, finishing with 320 or 400 grit....
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 07-29-2008, 11:42 AM
Slumlord
Caveats required: This will never look like a new dash. The areas that cracked and separated change shape, and no amount of 'body work' can bring them back to 'factory'.
So, moving on: Stage III is application of SEM's dash spray 'Texture Coating':
This leaves you with a foundation that is a bit rough, sort of likes it's been flocked (Z-man: that's a real word), so next is sanding with 400 grit to 'even out the surface' and knock the bumps off.
Which leaves this:
and this...
Last: A top coat of black semi-gloss bumper paint...
The pictures show more variation than the naked eye would normally see. It looks better than the pictures show, and once it's had a second coat and been re-installed it will look even better.
There are still a few areas where the finish is a bit rough, I will scotch-brite those areas and top coat them in the next few days.
Other notes: The finish on the textured spray depends on spray distance, do not go too far away, the can says 18", 12" is better.
There is obviously no grain like the factory finish, and I suspect the surface will tend to collect dust. Time will tell....
Total cost - about 20 gallons of premium, leaving me 100 gallons ahead. With a half-decent dash.
84 Cab - sold!
Old 07-29-2008, 11:53 AM
Designer King
Paulporsche's Avatar
Very nice!
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-29-2008, 11:59 AM
What does twp stand for?
Is it a trade name?
I was thinking of doing this to my dash.
Old 07-29-2008, 12:07 PM
Slumlord
Originally Posted by Paulporsche View Post
Very nice!
Thank-you, let's say 'a big improvement'.
Is it a trade name?
Doh... typo. TWO part epoxy...fixed now.
I tried to find the tube today but no luck. I'll post the info ASAP.
84 Cab - sold!
Old 07-29-2008, 12:09 PM
Thanks.
The problem is that we cannot have all the materials down here.
Old 07-29-2008, 12:12 PM
Slumlord
Thanks.
Basically it is five-minute epoxy, mix it and pour it in. I've also read that expanding spray foam insulation will work.
84 Cab - sold!
Old 07-29-2008, 12:25 PM
Fritz Peyerl's Avatar
dash repair
so what's your address? I will send 20 gallons of high test along. My dash looks the same, before the treatment.
Old 07-29-2008, 01:02 PM
Elombard's Avatar
Nice, any body know if there are any threads on replacing a rusty area on the back side and the studs associated with it?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 07-29-2008, 01:04 PM
Slumlord
Send it to me UPS (Toronto area) and I'll do it cheap...I prefer high test (single malt), but 20 gallons is way too much.
84 Cab - sold!
Slumlord
Never seen one, but a bit of silicone should work.
84 Cab - sold!
Old 07-29-2008, 01:05 PM
Formerly reformed
Flocking fabulous fix for fuel-focused . . . feral . . . something . . .
1968 911P (Paperweight)
Old 07-29-2008, 01:08 PM
Slumlord
Ford Focus?
84 Cab - sold!
Old 07-29-2008, 01:09 PM
Formerly reformed
FANATICS!!!! Yes!! That's the word. Fanatics.
Old 07-29-2008, 01:11 PM
Elombard's Avatar
Monkey why did you not go with a cover? This looks a little better but still a lot of work.
Silicone?? I am talking about the back side where the metal "sheet" is that the studs are attached. I would like to remove the metal plate and replace it but its buried in foam. I think I will try cutting out the rusted area and epoxy in a plate section with a new stud. I am concerned if I dont get the placement just right tje stud wont go through the hole in the dash...
Old 07-29-2008, 01:12 PM
RS 73
does anyone have any experience with dash covers for the 911?
I have one and am waiting to take the windshield out to install it.
Any hints? I know I have to do some work to make the old dash smoother in a few places etc..
Dick
Old 07-29-2008, 01:13 PM
kfosburg's Avatar
Send a message via AIM to kfosburg Send a message via Yahoo to kfosburg
I made some simple repairs to my dash which looked nice... but the underlying issue of it being very brittle caused more cracks as I started to put some miles on it... Do you think the finish applied here (which looks great imo) will help?
Karl
1971 911E
Old 07-29-2008, 05:48 PM
signature65's Avatar
I have a cover lay on my dash and I hate it. It looks incredibly cheap.
Darren
1973 911 T MFI
2005 997 Carrera
2001 Toyota 4Runner
Old 07-29-2008, 09:43 PM
4flyboy's Avatar
Dash topper
Ditto: I've been thinking of removing the cap and giving it the same treatment flock etc. The idea being to try and make the finish more acceptable. I have high hopes for this. The only downside is a hundred bucks for a new ugly cap. Big deal. I'll let you know how it comes out.
Scott
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 07-29-2008, 10:39 PM
I'll be recovering the dash on my cabriolet later this year. Stay tuned.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 07-30-2008, 05:28 AM
