Front Strut Mount Hex Size
I have searched and even looked in Waynes book but can'r find the size, I need to go buy one but need to get the correct size. Does anyone know the correct hex size needed to remove the front strut mounting bolts on a 1985 Targa? Thanks. Joe
1985 911 Targa 3.2 with 964 Body Kit
Old 01-18-2014, 01:18 PM
RETIRED
Joe Bob's Avatar
Could be anything from 10mm to 19mm, plus. Take a pic and post.
2012 ML350 3.0 Turbo Diesel
Old 01-18-2014, 01:20 PM
On an '80 SC, you can use either a 22mm or 7/8 socket.
I would also recommend that you go buy a cheap digital caliper, as it's sometimes easier to measure existing parts.
Old 01-18-2014, 01:35 PM
Here it is.
Old 01-18-2014, 01:44 PM
Just to verify, I am referring to the hex bolt on the left. I need to remove the two on the other side of strut nut to install a strut brace.
Old 01-18-2014, 02:04 PM
RETIRED
Joe Bob's Avatar
To me that's an allen head. 5/16 SAE or 8mm.
Personally I would go to sears and buy a set. cheaper than buying one at a time.
Old 01-18-2014, 02:09 PM
French Import
zippy_gg's Avatar
Ditto!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 01-18-2014, 02:47 PM
Spot on! That's why this forum is tops. Thanks.
Old 01-18-2014, 03:00 PM
testa-rossa's Avatar
It's 8mm. I just removed mine 2 days ago.
Old 01-18-2014, 09:47 PM
