 G50 syncro lifespan? For a predominantly street driven G50, any ideas on typical mileage to expect out of the stock syncros, particularly 2nd and 3rd? Mine's got 156k and 2nd is starting to get "crunchy" especially when cold. Barring any ham fisted shifts, when do most start rebuilding these? Mine's still good you just need to take it easy going to 2nd. Just curious.... Or perhaps I just need to drive a 915 for a while then my G50 will feel smooth as silk again! :D |
 Funny you mention about going into second; mine is also a little clunky, but only when cold (first few shifts, really). I've got 112K on the clock. Once the car is nice and warm, all is smooooth. FWIW, I put Redline 75-90 synthetic in last summer, and there was an improvement. |
 Mine Also Mine has about 220K and maybe 14 DE weekends.   First and more so second are a bit crunchy when cold also, budgeting a rebuild maybe next winter.  Will do a fluid change this spring sometime and try to really notice if any improvement.  Been 3 years and 30K or so since last fluid change. |
 Would synchro wear manifest itself first when cold?  Or would stiffer cold shifts be due to another problem?  I would think that temperature wouldn't make a huge difference, but I really don't know. |
 The synchros can go for years and years w/out rebuilding, even if crunchy.  They're not like the 915 which can eventually let go of the synchro pieces that then cau$e collateral damage to your tran$ Mine has 83K on it and has been crunchy going into 2nd when cold for a long long time. Usually takes only a few shifts for it to get better. I've tried all sorts of gear oils and none have struck me as being leaps and bounds better than the others. Mobil 1 from local parts store, Mobil 1 SHC/Delvac, Redline, Swepco, Valvoline HP dino. All seem about the same to me. I currently use the Valvoline in the white bottle and it works fine. I noticed in the past few years of track driving that the 3rd gear upshift and 2nd gear downshift would crunch as the temps got hot. The way I "fixed" that is to double-clutch on the downshifts and be more patient/gentle on the 3rd upshift. |
 Sounds like mine is on par for pretty much normal then.... not a huge deal, I just take it easy going into 2nd. Plus it's more "clunky" than "crunchy" so I'm not too worried about breaking anything in there. I may swap out the Kendall fluid for Mobil 1 or something similar to see if it helps any. |
 135K on the clock.  I take my time between all the gears, especially 1st to 2nd and 2nd to 3rd.  When cold, it's a little stiffer.  From 1st to 2nd I get what I'd call a slight "nick" feel from 1-2 and 2-3. Never a metallic sound or feel, just something.  Been that way since I bought it at 67K miles.  No better, no worse. Would be great to understand better indications of when a rebuild is necessary or indicated. |
 My suggestion is to never use the transmission for a downshift.  It is really totally unnecessary for modern cars with good brakes.  Even on the track, the downshift should be the last motion as you release the brakes and turn into the corner so that the trans is in the right gear for the corner.  Anything more than that is purely just ego. |
 I think you mean never use the transmission for engine braking?   Agreed, brakes are much easier and cheaper to service than clutch/transmissions and/or engine rebuild. To further awhnry's point, I think its a waste of coordination and clutch operation to sequentially change down gears under braking. For example, going from a long straight to a slow corner I go right from 5th to 2nd at the end of the braking zone instead of going 5-4-3-2. Easier to match revs/heel-toe at lower rpms as well, IMO. |
 My '87 has 226k miles on it. I wasn't told the gearbox had been rebuilt - but it shifts surprisingly well. I only get a slight "nick" (well said, pavegeno) on the 2-3 shift. Compared to the Alfa Romeos I had, this is downright miraculous. Still a joy to shift. Thanks -Glenn |
 Mine is a little crunchy into second when cold.  Smooth when warm.  Looks like the norm. 103K miles. |
 Quote: Originally Posted by chrisbruck View Post "Or perhaps I just need to drive a 915 for a while, then I'll know what I'm missing!" Quote:
 THANKS!! What was I possibly thinking... :D:D |
 Luckily my G50 shifts the same as when I got it over 20 years ago (I'm basically the original owner, it was pretty low miles when I got it).  Never crunchy, but it has the same cold-start notchiness in first and second gears as it had when 'new'. I will say that I have always shifted extremely gentle, using a very light touch on the shifter and matching revs on downshifts as best as possible. On a related note, I rarely use first gear once it's warm, I just startup in second gear. Avoids the upshift, and it pulls great off the line in second gear with almost no slipping of the clutch. Chuck.H '89 TurboLookTarga, 371k miles |
 Downshifting and loading the gearbox on track is NOT 100% about ego. It has its place in high performance driving, but like anything it's all about doing it in the right place at the right time in the right amount.  There's a turn at my local racetrack. It's a wide 180+ degree turn that transitions from entering on a fast downhill to existing climbing a hill. If one trail brakes into it in 3rd (as my car is geared) and drops it to 2nd just as you apex, it wags the tail barely, locks the LSD, and you launch up the hill with the throttle to the floor. I know guys who downshift to 2nd later in that turn and complain about how they push out to track out and have to lift because they aren't rotated enough. But that's at the track. On the street, downshifting and using the tranny to decel is just to feel cool and because the engine sounds neat. That's ego. I personally prefer avoiding absolutes when we start talking racecraft. There is usually at least one example that can be found to challenge the "all the time" claims. ;) |
 Yes, I appreciate the correction.  My post makes more sense with your addition. And yes, there are always exceptions to the general rules but again with modern automobiles, use the brakes not the trans to slow the vehicle on the street. And dont shift into first gear when the car is moving. On the racetrack, there will be exceptions just because you are trying to make pigs fly and deal with the car as it is rather than a perfect situation. Personally, my lap times went way down when I made a change in the final gearing which required far fewer gear shifts at Road Atlanta. I could spend that tiny amount of time concentrating on my braking and connecting the dots of turn in, apex and track out. |
 pushing 250k on mine with plenty of track miles.   The G50 is almost too good as I really want to do shorter gears but it's hard to justify a $10k bill on the perfectly good transmission.  At least with a 915 it gives you a reason to rebuild every 50k miles. :) |
 I love the turbo G50's that got the 3.154 instead of the 3.500. Though that's still miles ahead of the 3.818 that they adopted for pretty much all the 6spd boxes from 993 onwards. Useless in my mind, and so useless, that a GT3 owner's manual advises you to start the car in 2nd gear on certain occasions. Silly stuff, really. |
 Great point about not downshifting into first on decel. It takes me back to the first vehicle I ever purchased: my old '65 Dodge van, which had a 3-speed manual trans (shifter on the tree!). First gear was NOT synchronized, so you really could only shift into first when standing still. That taught me well about when and when not to downshift, and I practice that to this day. |
 I can live with the results; avoiding the behavior would force me to enjoy my car less, and what's the point of that? (NB: I drive it on dirt roads and in the snow, too ;) ) |
 I have never downshifted into first on decel. I do however downshift to second - sometimes just to hear the engine note. :-) I also feel more in control in a lower gear. Sent from my Nokia Lumia 1020 using Tapatalk |
 Downshifting to 1st is nearly impossible if the driver is clutching it only once just like any other gear.  The trans simply won't let you do it because it requires so much friction to spin up the synchros to match shaft speeds.  People who are able to do it are usually forcing the trans into gear and that's a big no-no.    If you must shift into first while moving, at a rather slow speed like 10 mph, you can make it work w/out leaning on the shifter by double-clutching. Still rolling along, push in the clutch, select neutral, release clutch & bring up the revs with the throttle. Hold that rpm (don't just blip it), push in the clutch and then select 1st. If you "guessed" right with your rpm selection, the shifter should slide right into 1st. Sometimes takes a few attempts to get the rpms right. |
 Please note that it has not been stated that you cannot downshift(in fact, a well-coordinated downshift is one of those AHHH moments in a car) but dont downshift to brake the car.  The downshift should be the last movement in the corner approach rather than the first and should not upset the car's balance or motion.  YMMV |
 There's another turn at my local track that I eventually learned not to downshift at all as I became a better driver.  I used to slow down too much. I needed 2nd. Then I got faster, and started bouncing the rev limit on the downshift eventually reaching the point where I chirped tires with the downshift. I'm sure that was brutal on my rod bearings (should have seen the oil pan on engine teardown). Now I take that corner in 3rd. :) |
 Back to the OP - have 123k and am in the process of rebuilding.  Similar to KTL mine would "pause" from 1-2 (which existed since 88k), which was annoying and was worse the higher rpm I revved to in first, and start to crunch when hot.   A couple thoughts - its NOT cheap, if you want it done right. Second, I wanted to replace the stock brass synchros with steel in all gears, and it was hard to find replacement parts. I guess Porsche recently ended their relationship with Getrag, and had to source new steel synchros with other suppliers. These suppliers have not had success with quality control, etc. so we had to find old Getrag produced ones. Something to think about as material cost is just about as much as labor in the rebuild. |
 My dealers have access to the old original steel synchros. I have a bunch of them, but only sell them through my shop customers.  That said they aren't an actual upgrade for a street driven car. They handle the heat and stresses of the track and racing better. But if its a street car, even one with a little DE use save yourself a few hundred bucks and stick with the old brass ones. |
 Lost a G50 synchro at 148k. Grinded horribly into 3rd gear. Before it went out, 3rd gear would get stuck pretty often when shifting into it. All rebuilt and fresh again now. Wallet still hurts though. |
 So what's the going rate for a G50 rebuild?  Mine's good for a while but would be nice to start saving. |
 When I got my 88 Carrera at 37k miles. The 1-2 shift was notchy when cold, just like people are describing for cars with 100-200k more miles. I think that is how they are. Mine now has 54k miles and feels just the same. After a very short warm up time the shifts are very smooth and fairly quick without forcing anything. |
 I've never felt mine was notchy given its age but I guess I could describe it that way in comparison to my 2012 Wrangler or other new cars I've driven. |
| All times are GMT -8. The time now is 05:40 AM. |
