Pop pops through the carburetor Zenith 40 tin.
Pop pops through the carburetor Zenith 40 tin. (sorry for my ingles)
Hello friends car costing the idle of 950 rpm. and accelerating quickly spits up of cabruradores.
I beg you to guide me. I uploaded a video for you to see the operation and help.
thank you very much:
Links:
https://www.youtube.com/watch?v=SnP8FeKLOR0&feature=youtu.be
https://www.youtube.com/watch?v=jBPuVoUEDV0&feature=youtu.be
Old 01-23-2014, 05:17 AM
1QuickS's Avatar
Check tips of idle jets for dirt, tip diameter is 0.475mm.
Mixture screws should be about 3 1/4 turns open to begin with tuning.
Spitting up is a lean condition so check for air leaks from your hoses attached to the bottom flanges of the carburetors and all other air hoses attached to your carburetors.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 01-23-2014, 09:10 AM
Thanked. Realmetne grateful buestra good arrangements to help.
3 1/4 turns out? and adjust the mixture screew mescla fattening?
is the initial posision idle stop screw? the screw that regulates the opening of the throttle valves?
Old 01-23-2014, 12:35 PM
My frien've removed the carburaor to make a clearance.
It strikes me how dark antencion butterflies. Look at the picture
Old 01-25-2014, 01:36 PM
Those could be carbon deposits on the valves. I'm no expert but I have read this would indicate that air is getting by the valves. You can read more here Weber Carbs Technical
Old 01-25-2014, 01:59 PM
IslandHopper's Avatar
Old 01-25-2014, 05:24 PM
