-   -   911sc Doorlock won't open! (http://forums.pelicanparts.com/porsche-911-technical-forum/79378-911sc-doorlock-wont-open.html)
Oxford_Hippo 09-02-2002 11:12 AM
Hi,
made the (big? ) mistake of locking the passenger door with the key, when the door wasn't fully shut.
Now using the key won't lift up the locking pin and the turn knob inside won't open it either
Don't want to force the key as it feels like it might break.
Help!!
any suggestions,
:confused:
island911 09-02-2002 11:15 AM
I would try shutting the door all the way. then try unlocking.
Oxford_Hippo 09-02-2002 02:57 PM
Hi Island911
had a go at pushing the door shut - but the catch just won't engage so it will not shut fully.
hope it doesn't rain tonight!
anyone else any ideas?
think I've been jinxed - washing machine lid jammed at the weekend as well, as bad luck runs in threes - what will lock next?
Bill Douglas 09-02-2002 05:15 PM
My 911 SC did that also - maybe because it's English. I bought it in Weighbridge.
I pushed HARD on the door while I turned the key.
stealthn 09-02-2002 07:20 PM
Go on through the drivers side and unlock it?????
:eek:
Oxford_Hippo 09-02-2002 08:12 PM
Bill - thnks for the tip, will have a go tomorrow ( it's 4am here ).
Morning Mr stealthn,
...and the turn knob inside won't open it either ...
but so as not to appear smug I'll try from the inside ( again )
:p
Oxford_Hippo 09-04-2002 11:37 AM
Happy again now, Soaked the lock ( the bits I coud reach through the gap in the door ) with WD40 and left overnight.
thought I'd have one last try at getting the door to shut fully before attepmting to get the door card off.
WD40 must have worked magic - with a fair amount of force ( pusghijg about level withthe locking bar on the car frame inwrads and upwards ) the door closed fully and then I was able to use the key to open it.
But think now might be the time to give both the locks an overhaul. The drivers locking pin doesn't drop down level with the door card when the door is locked.
so....
Do you need to replace all the locking mechanism - or are there any individual parts that can be replaced / lubricated to improve the lock?
thanksSmileWavy
TigerTrash 09-04-2002 12:13 PM
HAHA...Had to laugh. Same thing happened to me last weekend. IF in this position the lock on the inside doesn't work and turning the key by force will probably just snap off the key. There are some problems that just need a little force to be dealt with properly. I pushed hard and fast, got past the still closed/still open position of hell and the lock worked just fine. I doubt as weather the WD40 did anything for you . It was probably just more force than you used last time. Glad all worked out for you.
