Cornpanzer's Avatar
Can anyone help me out with the wiring diagram for a factory 1970 radio hookup?
I found the factory Balupunkt radio for my 70 911 S and Im not really sure how to hook it up to the harness. Can anyone help? Thanks, Dave C
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 09-02-2002, 10:02 AM
Dave,
I have a '69 which should be fairly close to yours. There is a switched 12v wire near the radio area (blue? from memory). Mine has a 90º angle female spade connector on it with a plastic insulating shield. You could also run a wire from the ignition switch over to the radio. Use one of the switched or unswitched terminals. A 12V test light or voltmeter will help ID the wire or terminal.
I've got a few high-res factory wiring diagrams on my website (PDF) you can download if that'll help.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 09-02-2002, 11:54 AM
Cornpanzer's Avatar
Thanks Sherwood, thats a terrific help =)
1970 911S,
RGruppe#252
Old 09-02-2002, 02:34 PM
