1stgear's Avatar
Skate or Scrape! No More Bottoming Out.
My car is pretty low. 24 1/16” at the highest point of the front wheel well arch. I got tired of my tow hook dragging bottom so I made a plate kit that sandwiches both sides of the hook. The new issue that addition created was that the hook had to be straightened to full length to add the plates and the car bottomed out even more. I was like there has to be a way to fix this, so I thought I should attach a wheel. But what kind of a wheel? I thought about that idea for a couple days and then a light came on - a skateboard wheel would work great.
Well, I assemble my idea after trips to the skate shop and hardware store. I was able to test my invention out this weekend and it worked like a charm. No scraping or scrubbing. Just the skateboard wheel hitting the asphalt and rolling. The bearings held up great and so did the bolt!
The pictures attached are before the wheel was bottomed out. That’s why it’s so clean. You can see where the plates had bottomed out though. The wheel extends .25” below the plate.
I picked up a passenger side factory two hook from Rick at Weekend Rides and plan to make the same setup for that side as well.
1985 M491 Carrera /Turbo-Look Registery #1727 / White Gold Metallic / Leather Recaro Pole Positions / Wevo shifter & shift joint / Fifteen52 Outlaws - 15x8 & 15x10 / Fabspeed RSR Headers and Muffler / AC delete / Appbiz RS Carpet Kit / Lakewell dash / Stratton Duck w/Al Kosmal grill / Elephant Racing 19mm spindles, coilovers, and quick-change camber plates / SW chip & throttle body
Old 05-31-2017, 05:13 AM
Not as it seems
juanbenae's Avatar
subscribed!
Old 05-31-2017, 07:47 AM
Occasional User
Cook&Dunning's Avatar
Looks better than this one. That's all I've got
Training wheels on my Porsche
Vince
2015 Boxster S, Black & Black
1989 Carrera Silver Coupe, Silk Grey - sold
2009 Cayman S White, Full Cocoa - sold
1972 911E Silver Coupe, Pepita & Black - sold
Old 05-31-2017, 07:55 AM
^^^ Oh My! Redneck engineering at it's best.
Derrick
Old 05-31-2017, 08:07 AM
group buy?
Old 05-31-2017, 11:44 AM
Flojo's Avatar
Fix that.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 05-31-2017, 12:38 PM
You now have the second six-wheel Porsche...
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 05-31-2017, 01:40 PM
Send a message via AIM to Hcarraro Send a message via Yahoo to Hcarraro
Great idea. Thanks for sharing.
Henry
Old 05-31-2017, 04:11 PM
Rescuer of old cars
Arne2's Avatar
Originally Posted by Flojo View Post
Fix that.
+1
When I bought my car, it too was really low up front, dragging the hooks frequently. After raising the ride height up a bit (still lower than stock) the car drives and handles much better. For street use, Porsche engineers knew what they were doing. I'll never drop mine back down.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 05-31-2017, 05:19 PM
Checked out
McLovin's Avatar
The thread title had promise . . . and it did not disappoint!
I never thought this could happen again . . .
Old 05-31-2017, 06:00 PM
Checked out
McLovin's Avatar
yep
Old 05-31-2017, 06:01 PM
Checked out
McLovin's Avatar
While this new one is in the same spirit, that original will NEVER be beat. The amount of drilling involved, the extensive use of hardware store items, the haphazard installation, it's a classic.
Old 05-31-2017, 06:03 PM
Bill Douglas's Avatar
Nice, but I still like my extra strong tow hook that takes chunks out of other people's driveways.
Old 05-31-2017, 10:13 PM
Armed Bastard
djb25's Avatar
That is one of my favorite threads.
I think about it whenever I work on my car - "Maybe I could just use... oh, no. Never mind."
Damion
'77 911S Turbo, EFI 2.7l, Carrera intake, Megasquirt 3 with MS3x, Fuel & Ignition
Old 06-01-2017, 07:58 AM
Just an idea and of course subjective. But why not cut those hooks off and run a tow strap instead if you ever had to pull the car? I love the idea but i wonder what the life span on this set up would be
Old 06-01-2017, 02:22 PM
