1stgear's Avatar
No Burble/Popcorn on Decel
I have a ROW '85 Carrera with a NA 3.2. I'm running Fabspeed headers with no heat exchangers and a dual outlet muffler with very little packing.
My question is this - every other 3.2 I've had (3) that I ran without a cat would make that nice popcorn sound on decel. This car doesn't. Any ideas as to why?
I know that sound comes from unburnt fuel in the exhaust. I currently have the car in for leaky injectors and intake gaskets. We're trying to fix all the vacuum leaks. Could this be the source of my missing sound?
Thanks for any help!
1985 M491 Carrera /Turbo-Look Registery #1727 / White Gold Metallic / Leather Recaro Pole Positions / Wevo shifter & shift joint / Fifteen52 Outlaws - 15x8 & 15x10 / Fabspeed RSR Headers and Muffler / AC delete / Appbiz RS Carpet Kit / Lakewell dash / Stratton Duck w/Al Kosmal grill / Elephant Racing 19mm spindles, coilovers, and quick-change camber plates / SW chip & throttle body
Old 12-07-2016, 11:35 AM
I've heard that it isn't just an exhaust that adds this burble on decal... it's a combination of air/fuel mix.
Are you running an open CAI kit in place of the factory enclosed airbox?
Do you have a custom tune?
1987 Porsche 911 Carrera Coupe
Old 12-07-2016, 12:51 PM
Rescuer of old cars
Arne2's Avatar
Carreras with Motronic shut off the fuel during off throttle decel, and because it is a more effective system in other ways, there is little unburnt fuel during decel. It's a better tuned system, and I don't think you can make it pop without changes to the engine management software.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 12-07-2016, 01:00 PM
1stgear's Avatar
I'm running a stock air box and tune.
My previous '85 and '87 had stock chips and they popped like crazy. So did my '95 993.
Old 12-07-2016, 01:07 PM
evan9eleven's Avatar
You want my CIS injection setup? With SSI's and Dansk muffler, I have enough popcorn on decel to feed an 18-plex movie theater!
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 12-07-2016, 01:18 PM
1stgear's Avatar
POP POP - Talk to me, brother! LOL
Old 12-07-2016, 01:24 PM
Originally Posted by 1stgear View Post
Talk to me, brother! LOL What's a CIS injection system?
The slow-throttle-response fuel injection system that you can't get parts for anymore, or modify much, or run hot cams with, that was replaced by the motronic in your car. Its not an upgrade just to get popcorn. JMHO
2004 Boxster S
Old 12-07-2016, 01:28 PM
1stgear's Avatar
LOL! Hey, Evan. I looked it up and changed my reply. Thanks for your insight into the system, brother!
Old 12-07-2016, 01:30 PM
Rescuer of old cars
Arne2's Avatar
Really? My '84 does not pop at all, either with stock or Steve Wong chip; with either the stock cat or M&K premuffler. While I don't mind a bit of burble on over run, if mine started doing that now after 5 years of driving it, I'd be concerned.
2018 718 Cayman 2.0
Old 12-07-2016, 02:13 PM
douglas bray's Avatar
All kinds of popcorn now on my car:
https://www.instagram.com/p/BFSRl5Yv9h5/
Old 12-07-2016, 04:29 PM
sugarwood's Avatar
I thought that burble was air/fuel igniting in the exhaust, meaning it's running too rich.
I used to get burble on decel with my Welt. chip.
When I changed it to a Wong chip, the burble went away.
1986 Bosch Icon Wipers coupe.
Old 12-07-2016, 05:50 PM
decel burble and popping is due to a lean condition usually on decel. The gas/air is not ignited in the cylinder and passes into the exhaust header, where it accumulates with discharge from other cylinders and is ignited by the hot headers or by a spark in one of the cylinders.
backfires are usually from rich mixtures. They are different.
CIS generally does not burble and pop because the catalytic converter burns up waste and also muffles a lot of the noise when combined with the muffler. Remove the catalytic converter or swap in headers and you will likley get some popping depending upon how your WUR is adjusted.
If Motronic shuts off fuel on decel, there is no fule to burn in the exhaust, so no popping.
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 12-08-2016, 04:32 AM
Slippery Slope Victim
NY65912's Avatar
Lean condition causes the popping on decel, and you don't want that.
MikeČ
1985 M491
Old 12-08-2016, 09:22 AM
